best of the best with lsj's inside plz
Old Jun 22, 2010 | 08:18 PM
stew_pidaso59's Avatar
Ok so the whole story is I got ottp stage 1 bout a year ago. also added vibrant header and high flow magnaflow cat with a 2.5 mandrel bent cat back with 18"resonator and magnaflow muffler. I went with canned tune from ottp for a while and then I added meth inj. and had zach do a custom tune on it. within a couple weeks of the meth and the tune I starting collecting black soot on my rear bumper near the exhaust. shortly after than i got a cel 0420 i believe that comes up cat problem. well now at 2500 rpms on level ground in 5the gear my vaccum is about 8 to 10 negative. my boost often hits 18 or 18.5 in wot.
Old Jun 22, 2010 | 08:20 PM
csementuh's Avatar
clogged cat caused by overly rich tune
Old Jun 22, 2010 | 08:48 PM
selfinfliction's Avatar
should've taken your crowbar and beat zach over the head with it instead of your cat
Old Jun 22, 2010 | 08:56 PM
so what are my best options at this point with a very small budget? I'd like to rememdy all those problems...
Old Jun 22, 2010 | 09:11 PM
Pedobear's Avatar
trifecta
Old Jun 22, 2010 | 09:17 PM
rockSTAR_SS's Avatar
Replace the cat and get a new tune. Probably look at a few hundred $$$ all together.
First things first. Have the cat. removed or have it replaced. I recommend replacing it. Catless sounds horrible on these supercharged cars.
Then talk to trifecta about a custom tune. They seem to be the cheapest professional tuners and are pretty reliable from what I've read. Perhaps you can find an independent tuner locally (besides zach) that can give you a spot on tune.
Old Jun 22, 2010 | 09:19 PM
freakta's Avatar
new tune... go from there... that would be the best thing to do...
Old Jun 22, 2010 | 10:58 PM
burntorange's Avatar
Just gut the bitch, and retune....make as much power as you can get You won't care what it sounds like when you are going fast and winning.
Old Jun 22, 2010 | 11:26 PM
mrbelvedere's Avatar
lmaorotf true
Old Jun 23, 2010 | 05:07 AM
You will care what it sounds like, no matter what. I thought I could live with it but it literally gets unbearable. I had a cat welded in about a month ago.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
grampss
Sep 27, 2015 08:51 PM
