Best Meth Kit??
Old Jan 22, 2010 | 02:37 PM
Supercharged Guy's Avatar
Best Meth Kit??
Buying a Meth Kit in the next couple weeks, just seeing what people think is the best one out there. I'm leaning towards the AIS one but not sure.
Old Jan 22, 2010 | 02:42 PM
Bl4des's Avatar
devilsown progressive kit with AIS trunk mount kit
Old Jan 22, 2010 | 02:46 PM
ls1fbody's Avatar
Haz l33t wheelz.
that new AIS kit looks amazing.
Old Jan 22, 2010 | 02:49 PM
Josh@ottp's Avatar
DevilsOwn has a new tank that will be out Feb 1st. I would wait till then, and if for a deal on it pm me.
Old Jan 22, 2010 | 03:00 PM
Yeah I heard that devils own is a good kit but wasnt quite sure about the AIS one and didnt know if anybody had issues with it or what not but If I end up going with the Devils own I deff. will pm you. thanks
Old Jan 22, 2010 | 04:57 PM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
I'm sure you've seen our new competition tank. If not check it out. Nobody has a better quality trunk mount tank then this currently. Compare for yourself.
We're also extending our special till the end of next week. Let me know if you have any questions or how I can help.
Rodney
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed us to also break up the floor of the tank to help control fluid slosh
Old Jan 22, 2010 | 06:15 PM
Caligula's Avatar
I still dont understand what these things do, or how they work.
I know they cool right?
Old Jan 23, 2010 | 04:45 PM
AIS's Avatar
AIS
Have you read our Tech articles on our website? This goes over water methanol in detail and explains how it can help an engine.
http://www.alcoholinjectionsystems.c.../articles.html
Rodney
Old Jan 23, 2010 | 08:25 PM
Thanks Im probably gonna buy your kit after tax return lol already have the money spent and not even in acount yet. nice setup btw very clean. how much again for that exact one?
Old Jan 24, 2010 | 03:02 PM
AIS's Avatar
AIS
Thanks. I'm really happy with how it turned out. Our goal was to make the nicest trunk mount tank in the industry bar none and we did just that. I designed it with everything I personally wanted from a trunk mount tank and thought one should have. We didn't cut any corners or costs to make this. The tank speaks for its self.
Features & Benefits Include:
*Top of the line billet mold for exact tolerances and perfect straight lines you can only get from a billet mold.
*Black shiny textured finish. Easy to clean and looks great no matter how old the tank is. No more white tanks with dirty greasy finger prints or marks on it that won't come out. Just wipe it down with armor all and the tank really shines.
*Aircraft style flush mount cap with stainless hardware. This cap assembly is very expensive and cost us a lot! We could have easily cut corners and used a cheaper plastic cap as our competitors but it wouldn't have offered the value, features or looks of this cap.
*Aircraft style cap allows the use of inserting safety foam inside the tank for the ultimate in fluid control during road racing and street use.
*Large 3/8" NPT fittings molded into the tank. We could have easily not spent the extra money it costs to engineered our mold with this feature and simply just drilled and screwed fittings right into the plastic tank as our competitors. But this would have been cutting corners again and given someone else the opportunity to out do us and make it better.
*Dual 3/8" NPT fittings allows the use of 1/2" pick up hose. Allowing our pump to out perform any competitors pump using the smaller restrictive 1/4" hose. Essential for our 1200+ horsepower customers who need every bit of their pump.
*Dual 3/8" NPT fittings also allows our tank to be used as a trunk mount 3 gallon reservoir for air to water superchargers. Not just a water methanol tank. Simply remove the plug and you can now run both feed and return lines.
*Dual 3/8" NPT fittings allow the use of a second pump for our extreme applications which require the use of two pumps. Sounds crazy but it happens.
*Custom bent aluminum mounting straps to fit the tank perfectly. Each strap is also machined for a nice brushed look. We could have just bent the straps and called it done but we didn't.
*First trunk mount tank with built in virtual sump with rear pick ups.
*3 Gallons capacity vs competitors 2.5 gallon.
*Pump reversed under the tank for a clean, stealth appearance above. First and only of it's kind.
We are extending our sale to all of next week. Great time to save $70.00 off a kit.
AIS Stage 1 Competition Trunk Mount $349.99 (normal price $419.99)
AIS Stage 2 Competition Trunk Mount $479.99 (normal price $549.99)
Rodney
Old Jan 25, 2010 | 11:41 AM
devilsown's Avatar
Yes we should have the tanks in quantity to sell by feb 1. I should have one in hand latter today to post up actually pictures of the item. These are made by the same people that made harwood fuel cells. Which was one of the best fuel cells on the market. These are much higher quality design tht allows for proper cooling of the pumps bearings.
2.5 Gallon Sumped Tank DevilsOwn Injection
Our 2.5 Gallon tank from DevilsOwn is the first water-methanol tank with a built in sump and fluid control baffle. This eliminates the pickup being uncovered during sprinted driving. Because of the tanks quality design and it featuring a real sump in it. You can run the tank down to approximately 1 qt of fluid before uncovering the pickup. Made 1/4" thick and is same material and construction that is commonly used in manufacturing fuel cells.
Dimensions are 8" x 13.5" x 8.5". So It's best suited for trunk placement.
This tank features a 2 1/4" opening for easy fill up. This tank can be used for any alcohol water mixtures. It's 100% methanol compatible. Tanks design also allows for proper ventilation for the pump heat. Vented cap is included. This tank does not come with drain fitting. We recommend our self sealing bulkhead.
  • Features a real sump
  • Internal baffle for fluid control under braking
  • Same material and construction as fuel cells
  • Proper cooling for the pump.
  • Includes brackets and mounting hardware
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
