best pulleyfor the money?
look for a guy on eBay selling pulleys named nherbst454...he makes any size you want, and it will fit the GM stage 2 hub. He's also on here, but im not sure of his username...i think its nate...
The stage II pulley is a little under a pound lighter than the stock pulley. Nate's 2.9" pulley is I believe 12oz. lighter than the stage II pulley at 4oz.
https://www.zzperformance.com/cobalt...=529&catid=142
http://intense-racing.com/
http://cobalt-addiction.com/performance.htm
and i bet it you look hard enough you can even find a pulley boys set for the same price also
and last but not least , a pulley is a piece of metal all made with the same dimensions and another logo , hence the same price
the only gm "stage" pulley you can buy are 2.8's that match onto the stage 2 hub , there not gm products and zzperformance also sells those
so thats 4 places i found to buy pulleys ALL FOR 50$ EACH , ill say it slow for you , O-W-N-E-D
Last edited by Red2.4SS/SC; May 17, 2007 at 03:16 AM. Reason: Automerged Doublepost
^^ umm, all those pulleys cost more than $50 except for one and for that one you have to change the hub which tacks on an extra $100... oh yea, don't forget the pulley puller, another $100...
It all depends if you have stg2 or not... that's where the biggest difference is...
hey newb anytime you put on a new pulley your gonna have to change the hub , its not like they make press on pulleys that
are 3.0 inches and if they did and you bought one your not the smartest tool in the shed , o yeah dont forget the pulley puller
LMFA or you could just go to advance auto parts and rent one for free
money while i keep mine in my pocket
heres 3 different modular pullies all for under 60 bucks , like i said " THERE IS NO BANG FOR YOUR BUCK PULLEY"
Individual modular pulleys - $49.99 thats from zzperformance
Individual Pullies Your Price: $49.99 USD + $14.99 Shipping thats from cobalt addiction
Individual Pulleys for the INTENSE™ Modular Pulley System
Individual Pulleys for the INTENSE™ Modular Pulley System Quantity in Basket: none
Code: LSJ-IMP-xx0
Price:$59.99
theres intense's
thats 3 and all of them cost 50 except intense which is 60 , and if you bought there modular pulley system it woud only cost 100
Last but not least i would like some of you guys to buy nates 2.8 inch pulley and try and slap it on with no hub , your gonna feel like a ****** idiot
blah
blah
blah
blah
blah
blah
Oh look, my original comment - "It all depends if you have stg2 or not... that's where the biggest difference is..." - and you can even find that quote on your own comment... so keep it up and call everyone names - we obviously don't know as much as you...
"ill say it slow for you , O-W-N-E-D"
geez, i sense a little hostility here... but your not very good at reading thoroughly. Let's look/read the facts big shooter. I'm a "newb" to you as I've been on here longer than you - good one... oh sorry, don't have as many posts as you... I guess that makes me lower than you and the high pedestal you're apparently on huh?? So anyways - IF, you read my post, I pointed out that those pulleys yea, may be fifty bucks BUT you need their hub - the OP has STAGE 2 - hence, NO REASON to go to zzp or intense as he'll be SPENDING more $$ out his pocket as he could get Nate's pulley SHIPPED for $55. Oh, NO pulley puller needed - just a 15mm wrench and supplied Stg2 bolt wrench.
Just to let you know the post you initially responed to was in regards to pulleys that fit the GM stage 2 hub, therefore no different pulley specific hub is necessary. Also, Intense doesn't sell any pulleys to fit the GM stage 2 hub and the ones form ZZP are actually 69.99.
I believe that my pulleys are the lightest on the market. A 2.8" pulley for the Stage 2 hub I shipped today came in at 3.3 oz including the bubble mailer it was packaged in. This is from the weight indicated by the post office receipt I have.
Nate
Nate
I just ordered one of nates 2.9's.. Does anyone have any advice installing it? Like how easy is it to get the belt back? I dont want to take it off and not be able to get it all back on.. It seems very tight.
i had to run my original belt the when i put my 3.0 back bc i couldnt get the stage 2 belt around the pulley , but that .1 of an inch might help , good luck
Last edited by Red2.4SS/SC; May 17, 2007 at 11:04 PM. Reason: Automerged Doublepost
What puller is everyone using to get off their stock pully and put on their new hubs?? and where did you get it?? also, would it be ok to run 2.6 and 60lbers for a while with out a h/e. does it actually increase hp or just cool off the temps. i dont know whether to start my project until i get the h/e (its on backorder) or just wait so it doesn't mess up the tune. but idk so some input would be great. thanks
