Black Smoke
Black Smoke
Hey Guys, I have Black Smoke coming out from my exhaust when I push the gas and changing gears. Could it be need to be tune ? Cause I did got OTTP tune with 42lbs, 2.9 pulley, ZZP 3" CAI, Dual Bypass, Option B Tank, Phenolic Spacer, Bad Mab, ZZP 3" Catted Downpipe with 2.5 exit, and ZZP 3 Chambered Exhaust. So far no check engine light come on at all only seeing Black Smoke come out when I rev my car or going on a drive and changing gears can see Black Smoke. I dunno if I need to get my car tune. I know it could be running rich and it could be dangerous. I may be wrong, I just need ur advise what I am suppose to do with my car.
I am gonna get my car tune by professional in my area n Yes they had been tune somebody Cobalt before. They are charging me $200 dollars 1 time only then after that I can keep going back to them if I am modding my car more. That's nice.
Just needs a tune. Probably the canned tune you got from OTTP is just a conservative rich tune to keep things safe. You may still get a puff of smoke when you first go WOT, at least I do, but only people outside the car can notice it.
With my OTTP stage 2 canned tune after I hooked up my wideband it pegged 10.0 a WOT. And the gauge only goes to 10.0 so who knows how rich it was. Like stealthy said, you need a wideband to get an actual answer.
I would Love to get wideband but my budget don't cut for it right now. I will get wideband in time. I did told the professional to look at my Air/Fuel and make sure they are safe. They will take care all of that next week, I will meet with them.
They should cause it should be in their laptop ?
If not then I can make an exception to ask them if they can do that ?
You might want to ask them ahead of time if they'll even tune you. Lots of tuners will not.
I dont remember what the wire is called but there is a wire thats part of the windband that your tuner is going to have to connect to the box for that information to get to the laptop
[QUOTE=alleycat58;6472094]Um. If a wideband isn't in your budget, what do you have saved up in the very likely case that the tune is off due to the lack of a true wideband something like a piston or ring melts?
What's "in" their laptop? The LSJ does not have a true stock wideband a/f sensor. Doesn't matter how high tech they claim their stuff to be, they can't create a sensor that doesn't exist. They can read some data, but it won't be nearly as accurate as having an actual wideband.
You might want to ask them ahead of time if they'll even tune you. Lots of tuners will not.[/QUOTE]
True statement here
True statement here
Hey Guys, I did talked with the professional tuner and he said he will put wideband sensor in my car to get my car tune then he will take it off. So, I am good to go right ?
I mean, if you're OK driving around in a tuned car with no wideband, it's your ass. Well, your car's ass really. I wouldn't be comfortable doing it, most other people wouldn't be comfortable doing it. But if you want to do it, your choice. Just realize if something is amiss with the car or the tune, a wideband is one of if not the best way to tell there's a problem before the engine blows. When people have done this in the past, things have not ended well.
Just do yourself a favor. DON"T TUNE THE CAR UNTIL YOU GET A WIDEBAND! There is no way around it so just wait. The canned tune that is in your car now if perfectly fine for the type of driving that you are doing. /thread
The tuner is going to use a WB controller, hooked the WB o2 to the front sensor, and hook it to his HPT or w/e he is tuning with. (more than likely) I have seen this done when the customer doesnt have a WB. It is basically the same thing but the customer obviously wont be able to see the AFR after the tuner is done. On pump gas they dont have as seriously of a blend change as say E85 so the AFR should flucuate much from when it was tuned unless they have a vacuum leak or something else serious going on.
