BLE adjustable lifters
Old Apr 6, 2015 | 07:44 PM
ezjarecki's Avatar
has anyone ever used these? and an real instructions on specs to adjust them?
Old Apr 6, 2015 | 09:25 PM
mrbelvedere's Avatar
BLE they are out of buisness jesel 850 a set and you shim for clearance or bates 150 a set and they are machine to fit and dont use them on a hyd cam
Old Apr 6, 2015 | 09:41 PM
ezjarecki's Avatar
I have a set of BLE coming tho lol
Old Apr 6, 2015 | 09:47 PM
good for you I tried for a year no reply on emails no one would answer the phone so but from my digging I discovered they did not hold up well so I chose jesel
Old Apr 6, 2015 | 10:02 PM
ezjarecki's Avatar
why do they not hold up as well bc of the adjusting it needs every so often?
Old Apr 6, 2015 | 10:13 PM
some said they broke idk personaly but not being able to contact anyone and what i read i decided to stay away
Old Apr 6, 2015 | 10:21 PM
ezjarecki's Avatar
well thanks for the info so I guess ill give them a test and go from there
Old Apr 6, 2015 | 10:25 PM
go for it lmk how it goes remember you cant run them on hyd cams it will cause the valve to bounce off of the seat
Old Apr 23, 2015 | 11:45 AM
ezjarecki's Avatar
hey just a little info if you wanted to know but the new ble solid lifters are shimmed now and not adjustable with a jam nut
Old Apr 23, 2015 | 12:06 PM
JapEatr's Avatar
South Central *********
these are lifters or rockers?
Old Apr 23, 2015 | 12:40 PM
lash adjusters and post a link
Old Apr 23, 2015 | 04:07 PM
Josh@ottp's Avatar
BLE still makes lifters for the Ecotec. I haven't seen the new ones though if they are different.
Old Apr 23, 2015 | 04:56 PM
ezjarecki's Avatar
here is what i recieved im using a l61 head on my 2.2 supercharged they should be the same for the lsj i believe. i know my old 2.2 lap head wont work with shims tho bc there is a valley they could slip into
Old Apr 23, 2015 | 05:55 PM
Area47's Avatar
Rent me! per hour
you can't run those in the lsj as that shim will be in the center of the head after one heat cycle.
Old Apr 23, 2015 | 06:44 PM
ezjarecki's Avatar
Ahhhhhh well that's no fun
Old Apr 24, 2015 | 07:10 AM
i think all the eco heads are the same in the lifter area
Old Apr 24, 2015 | 12:31 PM
ezjarecki's Avatar
well my 2.2 lap head wont fit them but my l61 head will so i think they are all diffrent
Old Apr 24, 2015 | 12:36 PM
If the lap head is sandcast then it is likely the same as an le5 head.
Old Apr 24, 2015 | 12:45 PM
JapEatr's Avatar
I thought the HLA slid into a pocket, which would retain the shim?
Old Apr 24, 2015 | 01:31 PM
all ecotecs use the same lash adjuster
out of the gen 1 and 2 engines the lsj is the only head that is sand casted
Old Apr 24, 2015 | 02:37 PM
Area47's Avatar
Rent me! per hour
newp. There were a couple old timers that shimmed the lifters on the 272 cams and the shims slid into the center of the head and hung out there as there is no real way to make them stay put.
Old Apr 24, 2015 | 02:44 PM
ezjarecki's Avatar
here is the difference in my lash adjuster pockets if you can see them
Old Apr 24, 2015 | 06:56 PM
looks the same to me all ecotecs gen1 to 3 use same lash adjuster
Old Apr 26, 2015 | 07:16 PM
Speedytec's Avatar
Think you need some glasses, as these adjuster pockets look very different. ;-)
Old Apr 26, 2015 | 09:29 PM
ezjarecki's Avatar
yes there totally different one has a huge gap where they can fall thru
