Blowing out cats
Blowing out cats
I have a 05 ss sc gm stage 2 zzp mid length header zzp 3inch dp to 2.5 also have magnaflow 2.5 catback Injen cold air. Currently am unsure if my balt is tuned because the previous owner did the gm stage 2. I think it might be the stock tune i know if it is its doing nothing but hurting my motor. So my question is could this be why im blowing out cats? I have been threw 2 in the last few months 1st was a vibrant high flow and now a zzp and also one flex pipe.
Chances are, it's just due to the cold start. Try letting your car idle and get up to temp, shut it off and restart it. See if it happens again.. There's like a 1% chance of your valve seals leaking.
Maybe it does have the GM stage 2 tune, and you're just running fairly rich.. Because GM stage 2 tunes are pretty rich for safety purposes.. & it's clogging the hell out of your cat
I did this and once warm it dosnt smoke. I figured it was just running ritch on cold starts.
And see this is why it sucks getting a car you didnt install the parts yourself. Then you have no idea what the other person did. Now im just guessing if its tuned or not it sucks not knowing for sure.
Chevycobaltss3 is kinda close. Also team Ss is here in Huntsville Al. Im not sure if he is affiliated with trifecta or if he HP tunes though.
Team ss doesn't tune, he does remote tuning through james(ccss3). I would pm chevycobaltss3 on here. I live in tn too, where are you located?
