boost?
Old May 23, 2007 | 01:14 PM
doubleC's Avatar
boost?
i just got a new ss/sc 2 weeks ago and its only runnin 4psi...about 3 months ago the dealer did somehtin to the PCM, would that have anything to do with this...and how can i fix this
Old May 23, 2007 | 01:16 PM
SSCobalt~SSZ24's Avatar
well the boost gauge isnt mechanical and does get its reading from the PCM.......so maybe what did they do to the PCM and why did they do it?
Imlikedrpepper's Avatar
make the dealer fix it. keep taking it back. if your only boosting 4 psi, your guage might be fucked up, or literally your only boosting 4. You should see about 11psi stock
Old May 23, 2007 | 01:24 PM
doubleC's Avatar
well i take it in to the dealer friday to get my headlights adjusted so il have them deal with it...
my friend told me that if i unplug the PCM for a few minutes and connect it back that it will fix the problem...is this true?
Old May 23, 2007 | 01:31 PM
Psykostevo's Avatar
You need a lot more than 4psi.
Old May 23, 2007 | 01:34 PM
doubleC's Avatar
ya i know, i just noticed this the other day...i dont know y its so low wheher the dealer did it or not
Old May 23, 2007 | 01:47 PM
SSdan's Avatar
Maybe they put a 4.5" pulley on there without you knowing
Old May 23, 2007 | 03:19 PM
doubleC's Avatar
does anybody know where the PCMis located?
Old May 23, 2007 | 03:26 PM
handyjoe's Avatar
Its under the hood. If you want to reset the PCM, walk to the trunk and disconnect the battery.
You sure this is under full throttle, right? You won't get full boost sitting at a stoplight.
Old May 23, 2007 | 04:43 PM
doubleC's Avatar
ya last night me and my friend were testin its limits and it was only goin to 4psi
ya we disconnected the battery and it didnt do anything
Old May 23, 2007 | 05:59 PM
DO NOT DISCONNECT THE PCM!!!!!!!! Discconnect the battery for 20 mins, and the pcm will be reset to stock. IF you have stage II, and you disconnect that battery for 20 mins, it will just reset the computer to the stock Stage II tune.
You HAVE to disconnect it for at least 20 mins.
Old May 23, 2007 | 08:53 PM
handyjoe's Avatar
Any chance you accidentally got a gage reading kPa?
Old May 23, 2007 | 10:07 PM
doubleC's Avatar
20 minutes...i only let it sit for like 3 or 4...thanks, and whats a kPa?
i had it disconnected for about 25 minutes and it still isnt fixed any other suggestions or shouldi just let the dealer fix it
Old May 23, 2007 | 10:39 PM
Johnboy12358's Avatar
I say take it back to the dealer, its a warranty issue
Old May 23, 2007 | 10:42 PM
MaJ's Avatar
MaJ
That doesn't even make sense.. kPa is a significantly higher reading then PSI.
I run a little over 90kPa at WOT which is roughly 13.5psi. (P.S. I'm stock.)
Old May 23, 2007 | 10:52 PM
sunfirejoe's Avatar
sounds like u have a bad cat ur running 13.5 stock
and your math is off,
6.975 kpa per PSI so its roughly 12.9 psi. and our stock guages suck your prolly getting 12.5 only
Old May 24, 2007 | 12:29 AM
Mikey851's Avatar
I know it's not possible, but if the gauge was in Megapascals like a WRX it would make more sense haha.
Old May 24, 2007 | 12:34 AM
Rangerondubz's Avatar
Im seeing 15 on a cold night, I have intake, exhaust and a tune
Old May 24, 2007 | 01:14 AM
sunfirejoe's Avatar
megapacals would just read 0.09 instead of ninety lol
id rather read Bar instead of megapascal, i prefer kilopacals to megapascals as i prefer psi to kilopacals lol but inreality there all just gauge pressure, you have to add atmospheric pressure yet to get absolute, k im done being a nerd lol
Old May 24, 2007 | 08:30 AM
handyjoe's Avatar
Ok, so no then.
Take it to the dealer.
Old May 24, 2007 | 11:31 AM
doubleC's Avatar
well i disconnected the battery and now my check engine light is on, so im just gonna bitch at the dealer and make them fix it...im pretty sure they r the ones who fucked it up in the first place...
Old May 24, 2007 | 04:31 PM
Mikey851's Avatar
Haha, stage II kit has a maximum boost of exactly .1034211 Megapascals.
Old May 24, 2007 | 05:11 PM
Area47's Avatar
Rent me! per hour
you're running 18.7 psi
figure that one out
Old May 24, 2007 | 05:20 PM
Mikey851's Avatar
figure that one out
.128931961 Mpa haha . I'm using a calculator obviously.
Old May 24, 2007 | 08:54 PM
sunfirejoe's Avatar
well 1 megapascal = 145.037738 psi
so if i figure out math wise
i take .1034211 mulitpliy it by 145.037738 psi
you get 14.9999624054718 PSI, lol so 15 psi
who needs a online calculator when u got conversion sheets
i need them daily for work so yah lol
