Boost Control
Old May 2, 2007 | 02:45 AM
scottw03's Avatar
Boost Control
How do you guys control what boost you run on the car? Can you use boost controllers with a SC? or does the pulley set you at a certain level of boost and you are stuck there unless you upgrade the pulley?
Sorry, never looked into SC's before only turbos so this is a stupid question but just wondering how you guys raise or lower your boost.
Old May 2, 2007 | 02:48 AM
$uperman's Avatar
your boost is controlled by the size of your pulley
Old May 2, 2007 | 04:06 AM
martinsmu's Avatar
Hp tune can limit your boost in certain gears, however you need to spin ure SC fast enough to create max boost before you let it bleed.
Old May 2, 2007 | 06:23 AM
NJHK's Avatar
Just to also clarify...
Boost controllers are for turbocharged systems. What it does is delay the actuator signal to the wastegate making it open later...hence your turbocharger will be spinning faster before the exhaust flow is diverted to maintain a certain turbine speed. The more delay, the more boost that can ultimately be created.
Old May 2, 2007 | 11:16 AM
Area47's Avatar
Rent me! per hour
you can limit the boost in the first and second gear with HP tuners.
i have mine set at 10 psi in first gear. helps a ton! second is wide open, i dont have traction issues in second.
Old May 2, 2007 | 12:39 PM
scottw03's Avatar
LOL, that is because you are only pushing 233 ft of torque. LOL Just kidding. Those aren't bad numbers for a cobalt 260 something hp. not bad.
Try my car with over 350 ft of torque on the stock size rims and all season tires. Trust me, you will have traction issues in 2nd. LOL
Ok, so what I see at the moment is that you are restricted to whatever max boost based on size of the pulley you are running. That kind of sucks. Ok, good info to know. I will keep that in mind with helping with my friends SS/SC.
Old May 2, 2007 | 01:31 PM
Area47's Avatar
Rent me! per hour
i had a car with over 400 ft lbs to the tire. {the gxp} yes i know all about traction issues. first gear is insanely short in these cars, hence why i have the boost limit.
the gxp on the other had, it had violent torque steer at 75-80 mph. to the point where i almost hit a friends supra because of the initial hit from the bottle
Old May 2, 2007 | 02:47 PM
MTchevy1's Avatar
Now YOU try my S10 with over 450lbs of torque on street tires, then you'll see traction problems in 3rd
Old May 2, 2007 | 02:53 PM
Cobalt_SSTuner's Avatar
or you can use a manual boost controler (or so i've heard) to control the maximum boost.
Old May 2, 2007 | 03:55 PM
NJHK's Avatar
It doesn't work as well as you think
Old May 2, 2007 | 03:56 PM
scottw03's Avatar
Not trying to start a torque war here LOL. At stock torque I didn't have as much of a traction problem. Now I do. Haven't been to the dyno since I installed the new turbo so I don't know where I stand with power at the moment. Should find out on June 9th.
Anyway back on topic. Boost controller, ok so you can't use a MBC to control boost like in an SRT-4 or WRX, STi, etc.... right?
Old May 2, 2007 | 03:58 PM
Admiral Jedi's Avatar
That's what I thought too, so I bought one. It can only disable boost completely or let it be 100%. It's adjustable, and I couldn't make it useful. My car is slow without boost.
Old May 2, 2007 | 03:59 PM
MISSMATCHEDFACES's Avatar
you can tie the boost controller into the wastegate.
Old May 2, 2007 | 04:04 PM
NJHK's Avatar
If you have a roots supercharger, you don't have a wastegate...
Old May 2, 2007 | 04:08 PM
boostbalt's Avatar
Lol this is funny, it's turned into a who's got more torque pissing contest. Hey let's start the who's got the biggest dick contest and who's got the most money contest too!
LMAO at the people who have "big torque", come on guys....
Old May 2, 2007 | 04:10 PM
the stock eaton has a wastegate
Old May 2, 2007 | 04:23 PM
That's where I put it, I tried flipping it around, it did nothing for me.
Old May 2, 2007 | 04:25 PM
Bryank930's Avatar
Wrong. Bypass valve. They do different things.
Old May 2, 2007 | 04:31 PM
NJHK's Avatar
Exactly.
Old Aug 7, 2007 | 07:26 PM
Boosted07SSSC's Avatar
Wait so on an all stock sssc how much can you safely run.
and will this actually increase performance?
Old Aug 7, 2007 | 09:02 PM
NJHK's Avatar
How much what can you run?
Old Aug 7, 2007 | 09:06 PM
Area47's Avatar
Rent me! per hour
cream filled cupcakes
Old Aug 7, 2007 | 09:24 PM
boost. how much boost.
on stock system
Last edited by Boosted07SSSC; Aug 7, 2007 at 09:24 PM. Reason: Automerged Doublepost
Old Aug 7, 2007 | 09:35 PM
Shanman's Avatar
85 lbs
Old Aug 7, 2007 | 09:37 PM
Blurred Vision's Avatar
a 2.5 pulley with a ported blower 60lbs injectors and a perfect tune u can run 23 to 24psi but u better invest in every cooling mod axels , and run drag radials cuz the stock tires wont catch traction till 3rd if ur lucky
