Boostin while stopped
Old Oct 10, 2007 | 10:28 PM
PolishPauL's Avatar
Exclamation Boostin while stopped
Jus today on the way home, i noticed that when my car isnt movin and is in neutral, the boost goes up to 17.5 to 15HG at most. The A/C or any kind of air was off.
I think it might have somethin to due with my Fujita intake. It pushes out the fender and maybe theres a hole in it or somethin but i cant see nothin without takin off the fender. I noticed when i turn my steering wheel all the way my boost goes up a lil.
Any idea on what could be wrong?
Old Oct 10, 2007 | 11:05 PM
bigjoebowski22's Avatar
that's the ECM opening the throttle more to compensate for the parasitic loss of the alternator caused by the electonic steering trying to force the wheels to turn farther than they should.
Totally normal, you aren't "boosting" either. Boost is anything above 0psi, you're actually pulling vacuum below zero.
Old Oct 11, 2007 | 12:14 AM
PolishPauL's Avatar
But do you see more then less then 20HG when you are stopped and you let off the clutch? I dont remember this ever happening before but maybe i never noticed it.
+rep for the help
Old Oct 11, 2007 | 12:38 AM
Ryze's Avatar
a good healthy engine should pull anywhere from 16-22inches of vaccum at idle. less if A/C is on, or some parasitic draw (ie, power steering, alternator) is on the engine
Old Oct 11, 2007 | 11:04 AM
Area47's Avatar
Rent me! per hour
thats not boost, thats vacuum.
Old Oct 11, 2007 | 01:17 PM
Formula96's Avatar
your gauge might be off a little as well, when i am in key on engine off, i will see 1psi on my gauge.
Old Oct 11, 2007 | 04:30 PM
PolishPauL's Avatar
Me too but i jus wanna know wat everyone is seein on their gauge when the engine is runnin and ur stopped wit ur foot off the clutch. Im pretty sure that this jus started happenin tuesday so im still worried somethin is wrong.
Old Oct 11, 2007 | 04:32 PM
NJHK's Avatar
ROFL
I don't think anyone noticed...
Plus...
If you're in neutral, not moving and you're not putting any pressure on the throttle pedal, your throttle body plate is CLOSED and you're ingesting air through your IAC.
Old Oct 11, 2007 | 04:36 PM
Formula96's Avatar
Originally Posted by NJHK
ROFL
Plus...
correct me if i am wrong, but we dont have an iac, we have an electronic throttle body that controls the idle....
Old Oct 11, 2007 | 04:40 PM
Area47's Avatar
Rent me! per hour
actually no, the tb is shut during idle. there is a small hole on the back side of the tb that controls idle via a valve outside of the tb.
let me make this simple.
anything above zero on your hand dandy guessing boost gauge, is boost.
anything below this handy dandy guessing gauge is vacuum.
Old Oct 11, 2007 | 04:50 PM
NJHK's Avatar
"You are correct, sir!"
Old Oct 11, 2007 | 04:53 PM
Area47's Avatar
Rent me! per hour
as for what my car sees vacuum wise? it varies.
15-16 w/ a/c on
19-20 w/ a/c off.
Old Oct 11, 2007 | 06:18 PM
ecotecon18s's Avatar
if it rises up like that and keeps going to 15HG, your 02 sensor might be bad...one of mine went out and the car would start to vac up to 15HG....they replaced it and now its fine
Old Oct 11, 2007 | 06:21 PM
Area47's Avatar
Rent me! per hour
uuuuuuhhhhhhhhhhhhhhhh
ok.
Old Oct 11, 2007 | 06:23 PM
never heard of that, eh?
Old Oct 11, 2007 | 06:33 PM
Area47's Avatar
Rent me! per hour
unless you're idling at 500. i don't see it happening.
Old Oct 11, 2007 | 07:48 PM
NJHK's Avatar
This thread makes me lawl
Old Oct 11, 2007 | 09:47 PM
either way...its what the tech at the dealership told me...said the 02 sensor before the cat had exploded...lol they replaced it and it ran fine and has been since. I just go by what Im told...
...for the most part...
Last edited by ecotecon18s; Oct 11, 2007 at 09:47 PM. Reason: Automerged Doublepost
Old Oct 12, 2007 | 07:50 AM
NJHK's Avatar
uh huh
Old Oct 12, 2007 | 07:55 AM
steddy2112's Avatar
pancakes ftw!
Old Oct 12, 2007 | 10:32 AM
PolishPauL's Avatar
So your sayin whenever you put it in neutral your boost gauge goes down to bout 20 and then goes up a lil to maybe 15. I jus noticed that it does that when the cars movin too. If i rev my engine it the gauge goes up then back to 20 then to 15
Old Oct 12, 2007 | 10:42 AM
Area47's Avatar
Rent me! per hour
turn the a/c off.
it's fine, 15 is peachy with the a/c on. autometer is nothing more than an "approximation" gauge.
Old Oct 12, 2007 | 11:12 AM
PolishPauL's Avatar
turn the a/c off.
I never use the a/c. Thats why im worried. It just goes down to 20 then goes up to 15 but not smoothly.
Old Oct 12, 2007 | 11:24 AM
Area47's Avatar
Rent me! per hour
do a leak down and compression test.
Old Oct 12, 2007 | 11:32 AM
PolishPauL's Avatar
Dont know how to? Could it be a problem wit my intake? Should i go to a dealer?
