BOV on the M62
here:
Boost Bar - $159.99 : KaleCoAuto, Hard to find automotive items!
just get that installed and you will be able to run a BOV on the m62
Doesn't mess up much, like a BOV on any newer car it creates a post-maf air leak when open. The problem is that the blower is after the TB, so when it closes all the pressure goes away almost instantly. You have to basically give it a check valve and a resivior to make it work. In theory, it's pointless because it has no positive function. If you wanted to do it strictly for the noise, yes, it is possible, and has been done before.
First get this Turbo Whistler - Make your Car Sound Turbo Charged then crazy glue a BOV to the m62 and you should be fine!
lol,
or you can use this A Round Tuit [Art06] - $125.99 : KaleCoAuto, Hard to find automotive items!
YouTube - Mighty Car Mods - Blow Off Valves Mythbusted (SE02 EP03)
everything you need to know about bovs... and they prove that anything is possible lol
