Bulid Book Supercharger OverRev?
Old Mar 7, 2006 | 11:15 AM
automobiliben's Avatar
With all the talk about the new stage kits coming with only a 3" pulley due to over-revving it; it made me wonder what size the pulley was in the Build Book. So I pulled it out and checked, "The new GMPP 73 mm (2.874") pulley increases the RPM of the blower vanes...." My question is, where did people get the information that the blower redlines at 14k RPM (probably Eaton)? The redline of the Build Book is 7800 RPM versus the stage kits 7K RPM. So the supercharger is definitely over-revving (not sure of the exact RPM). Are they sacrificing performance for a potentially blown supercharger, I realize it is GM and they probably aren't worried about blowing the supercharger?
Old Mar 7, 2006 | 11:18 AM
1stbluSS's Avatar
Well actually the last gen M62 had a max spin rate of 14000 rpm the current gen which is in our cars have a max spin rate of 16000 rpm
Old Mar 7, 2006 | 11:25 AM
R33P3R007's Avatar
360 L337 User
how did you find this out?
R33P3R007's Avatar
360 L337 User
wouldn't 2.874 by 7800rpm be over 16000 also.
Old Mar 7, 2006 | 11:39 AM
BlackSS05's Avatar
noo on the one in the book it says m62 hybrid. take a look thats what the difference is.
Old Mar 7, 2006 | 11:43 AM
1stbluSS's Avatar
do a search on the model of M62 that the cobalt ss/sc has....
1stbluSS's Avatar
also you will not be spinning at 7800 rpm the stg2 kit only puts you at 7000 rpm
Old Mar 7, 2006 | 11:44 AM
1stbluSS's Avatar
also you can overspin as long as you have water injection or something too cool the heat of the air down and the sc......
Old Mar 7, 2006 | 11:47 AM
No, it says, "The stock supercharger can make the 300HP....The pulley will need to be replaces with a smaller unit." I don't see where it says anything about the supercharger being a hybrid.
Old Mar 7, 2006 | 12:08 PM
I am not talking about Stage 2, I am talking about the build book which has a redline of 7750 or 7800 RPM, the dyno chart isn't that easy to read.
Old Mar 7, 2006 | 01:13 PM
1stbluSS's Avatar
I would imagine at that high of rpm you would need at least water injection.... the heat created in the air with that small of a pulley and that high of a redline would actually take away hp as opposed to increasing it.... i would also imagine pistons and cams would be needed.....
Old Mar 7, 2006 | 01:23 PM
It doesn't seem like you know what the build book is:
https://www.cobaltss.net/forums/show...ght=build+book
Check it out, there is a lot of good information in there.
Old Mar 7, 2006 | 01:40 PM
1stbluSS's Avatar
i know what is it , i just havent read it ....
Old Mar 7, 2006 | 01:57 PM
campo165's Avatar
you can get a buildbook for free, i did...i just emailed some guy and he sent me one, free shipping and everything.
Old Mar 7, 2006 | 02:23 PM
03gobluecobra's Avatar
people have been overspinning the crap out of their sc's on cobras for a long time, and nobody really has much trouble with the blower seizing up. Even if it did happen, it's not very expensive to fix. Don't worry about it, just pulley it.
Old Mar 7, 2006 | 02:24 PM
1stbluSS's Avatar
screw it just put a 1.5 inch pulley on there and boost to 35 psi !
Old Mar 7, 2006 | 02:34 PM
memphisr24's Avatar
Hells yeah, or better, a 1 inch pulley. Anything smaller and you might need to fix the belt slip. However, there shouldn't be too much so you could probably use the stock supercharger belt.
JK!!!
I just want a company to come out with a bigger supercharger for our cars like the m90....or m112 . Sell it for around $500 and that would be sweet.
Old Mar 7, 2006 | 02:52 PM
R33P3R007's Avatar
360 L337 User
m90 swap, or the whipple twinscrew setup somehow. now that would be sweet.
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
medic710
Sep 6, 2015 08:53 PM
