Bwoody Heat Exchanger!!
Yae But It Was Test Fit On Our Cars Not The Ss/sc An I Know There Is Diffrent Bumper Clearance And What Not.. So Might Not Work..unless Bwoody Will Make Diffrent Brakets Maybe.. Idk For Sure Tho.. I Would Think There Is Enough Room.. A Ss/sc Want To Chime In.. Its About 2 Inches Longer Then The Cbra H/e An 3/4 Inch Deeper..
Depending on where they placed the fittings it may or may not work. Right now there is about 3" clearance between the Cobra HE and the A/C condensor, but with it being wider it will force it to move back further. It will probably be a very tight fit. Either way the fittings have to be on the side of the HE, not on the back.
go to the rl forums an hit new post it will b there or i can link it.... lol
http://www.redline******.com/forums/...exchanger.html
you know the deal replace the ****** with forums
Or photoshop the image and re-host it
By the looks of it, it will not work the on the SS/SC unless you mount it with the nipples facing forward and the HE mounted against the A/C Condensor. You would also want to move the plastic air damn to forward to direct the air to the front of the HE rather than the bottom.
But the CA HE has the fittings on the sides if I'm not mistaken. The BWoody has them on the front/back which takes away room, plus you have to have even more room to bend the hose without pinching it off.
n20saturn
09-30-2015 12:26 AM
