A/C delete kit?
I searched and found nadda. I wanna know if ne one ever found a kit or makes one?
why?
weight, that sucker is heavy.
talk to john powell if anyone knows he will
(Post 6179674)
why?
...................ask why? lol. I want to do it....or at least see if its an option. Scrat is going in road race/street car mix....dont need a/c |
You will need a pulley to go in its spot. I would say it was easy, if you were not supercharged. you could just buy the cavalier ecotec with no a/c belt and have a belt that just ran crank to alt to tensioner. It would be 1 rib to narrow but thats not a big deal since the non lsj guys who are blown run our tensioner, blower, and alt 1 rib short.
If you find one let me know. I keep bugging ZZP to make me one with no luck.
Take the ac off and measure the length of belt you need. Im sure someone makes one close enough.
Originally Posted by 68nova200
(Post 6182210)
Originally Posted by mrbelvedere
(Post 6182348)
cant because of the blower talk to john powel
Mr. Belevedere is correct/ Just remove your ac compressor, undo the rear through bolts remove the guts and the compressor housing, then bolt back on the car this will be the front compressor nose bracket with pulley and bearing . U u r done. Lite, cheap, no cost to you and perfect belt alignment.
PS be kind to the environment and first have the a/c charge properly removed with a/c equipment. |
the ac pump and compressor together both weigh exactly 25lbs. never measured any of the lines though.
will doing that actually increase performance in some way?
less parasitic loss.. which is turn would be kinda like gains you would see from lightweight pulleys only with "pulley delete" in this case. faster revs too im assuming
well. the way i went about doing it. atleast 25lbs of weight savings, better cooling of the engine, and i bet i can rev to 8,000 faster than a stock lsj can make it to 6500
so your saying its worth it? lol is it just a one and done type deal or do you have to get it tuned after?
it would be smarter for you to get on a treadmill and loose 8lbs. also the a/c is electric. no loss unless you turn it on. thats why you dont bother taking it out.
Originally Posted by padlock
(Post 6218891)
depends on how extreme/expensive you want to go. personally unless you plan on strictly racing the car, i would stick to just gutting the compressor and leaving it's pulley. gains will be minimal other than weight, but it doesn't hurt.
Originally Posted by myfakeevo
(Post 6218898)
if its a minimal gain. it might not be worth it to lose ac
(Post 6218910)
theres no such thing as a zero friction pulley....... you still have a loss whether its electric or not.. not saying its huge though
or if you are getting into my age bracket, 1-2 hair follicles are more important. :lol: |
(Post 6218910)
(Post 6218898)
would i need to be retuned if i did this since the blower may or may not be spinning faster?
