Cadillac Throttle Body
Old Jun 27, 2007 | 08:10 PM
JMAc88's Avatar
I remember someone was trying to use a throttle body from an Escalade? Has anyone got any updates from this guy, his thread has been dormant for a while.
Old Jun 27, 2007 | 08:12 PM
Brian MP5T's Avatar
What gains do you plan to make here. Basically, you are Forced Induction, The flow will not change. (Non Measurable or Inconsequential)
Old Jun 27, 2007 | 08:40 PM
Smarty Art's Avatar
We used a larger GM throttle body. Can't remember what one, but it leaned the engine out a little bit. Only problem is that the throttle body opening and the opening on the charger are different sizes. So you have to trace the chargers opening and grind out some of the intake. In the end its not really worth it.
Old Jun 27, 2007 | 09:34 PM
Shermen's Avatar
I think you guys are thinking about the ls1 mass air flow. and I belaive few people have them on their cobalt.
Old Jun 27, 2007 | 10:39 PM
NapaGuy's Avatar
As well arnt different MAF's programmed for different cars and as such will muck about with the PCM..
we used to have this issue with our Foci and ussing Mustang MAF's. i could be wrong thouggh it has been a long time.
Old Jun 28, 2007 | 04:29 AM
Brian MP5T's Avatar
^^ Yes, Switching out the Mass Air would only serve one "Good" function... It would be something to put in your signature, and one more reason that GM would not fix your car if it broke.
Old Jun 28, 2007 | 05:20 AM
REIGN SS's Avatar
Original Hayden Fanatic
isnt that 2 functions:
1.)put in your sig
2.)GM not fixing your car
Old Jun 28, 2007 | 07:53 AM
djt81185's Avatar
How is it not worth it? We saw a .8 A/F change toward lean indicating a lot more air is flowing now. for 125ish and some time witha dremel i think its worth it
Old Jun 28, 2007 | 01:36 PM
chevytech's Avatar
im gonna have to agree here if your seeing an indication towards lean after swapping throttle bodies, then it would be reasonable to assume a much larger air flow. lets put it this way if you put the s/c on a flow bench with a larger throttle body in the WOT position. you guys are trying to tell me you would see the same air flow? as with a smaller throttle body? if you increase the size of the inlet and outlet of any object regardless of what it is you can generate higher volume at lower pressures. i can see how this throttle body along with a ported blower would allow us to run our tiny lil blowers in a far more effecient way, if we facilitate a higher volume of air we can run lower boost meaning less heat and more power. all at a safer temp and boost range
Old Jun 28, 2007 | 01:54 PM
Omega_5's Avatar
1.)put in your sig
He said one GOOD function.... the other is bad...
Old Jun 28, 2007 | 02:50 PM
JMAc88's Avatar
The reason i ask is...
1) We are working on a 3.5" intake with an ls1 maf
2) the eaton will be gone soon enough
As for not getting any gains with a larger thottle body because were FI, tell the GTP guys that. They have noticed wonderful gains with a larger throttle body including increased boost readings.
So it was done? How hard was it? Was it an escalade throttle body? Can you pm the materials required and any problems you ran into.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
