cams............
Old Mar 13, 2009 | 11:09 AM
dougyfresh's Avatar
cams............
Do i have to have cam gears to put in the comp cams in??????????????????
Old Mar 13, 2009 | 11:15 AM
ShortStack's Avatar
No...
Old Mar 13, 2009 | 11:18 AM
slowswap's Avatar
You technically need cam gears, thankfully your car came with them stock.
I'm such a jackass.
Old Mar 13, 2009 | 11:25 AM
ShortStack's Avatar
Lol.
Old Mar 13, 2009 | 11:59 AM
Brandon97Z's Avatar
haha
Old Mar 13, 2009 | 05:55 PM
XM15's Avatar
I didn't think comp even made cams for the lsj.
Old Mar 13, 2009 | 06:13 PM
StevesBlack06's Avatar
they could prob make you cams for a pushmower if one were ever so inclined to do so.
and no you do not need ADJUSTABLE cam gears to run aftermarket cams.
Old Mar 13, 2009 | 06:20 PM
TurboTechRacing's Avatar
No... But keep in mind the comp cams do not fit the LSJ 2.0L, even though Comp Cams publishes they do... They don't...
Old Mar 13, 2009 | 06:33 PM
Muncher's Avatar
Why not? I plan to and know at least one other person who is running comp cams in an LSJ head...
Old Mar 13, 2009 | 06:36 PM
tdipowered's Avatar
well thats just bad advertising
Old Mar 13, 2009 | 08:36 PM
Who has them? Without modifications? It has been discussed many times, the exahust or intake cam (cant remember which one) is longer on the 2.2L. The 2.0L uses a shorter cam... (I think the intake cam)
Read up on it, you maybe suprised...
Old Mar 13, 2009 | 08:53 PM
red06SC's Avatar
What is with the influx of new members who want cams first lately?
Old Mar 13, 2009 | 09:05 PM
dougyfresh's Avatar
Is that legal? Cause look at this.....
http://www.compperformancegroupstore...e=CHEV464CAM20
Old Mar 13, 2009 | 09:42 PM
slowswap's Avatar
Most people don't realize you need to port the head on the exhaust side to take advantage of the cams.
Old Mar 14, 2009 | 07:01 AM
Muncher's Avatar
I think it's the other way round. The LSJ has a longer exhaust cam than the 2.2, however if you blank off the oil path at that end of the cam on the LSJ head then it fits.
A guy called vocky in the UK has done it, see here:
http://www.z22se.co.uk/forum/viewtop...10177&start=50
Old Mar 14, 2009 | 11:06 AM
Speedytec's Avatar
Yeah, but he is cheating a bit...
He (you will probably also in the VX ) runs that LSJ head without the cam sensor on a stand-alone ECU.
(Will work on the LSJ ecu too, if you don't mind cranking a bit while trying to start. )
Old Mar 14, 2009 | 01:01 PM
Muncher's Avatar
Ah right No cam sensor required for the VX and I'll be using the standard ECU to run the LSJ
Old Mar 14, 2009 | 06:38 PM
dougyfresh's Avatar
so there is a way to run these cams? lol if so how would tht be? lol cause my dads gettin my head redone.....
