Cams.
Old Jul 3, 2009 | 09:34 PM
Zach06CobaltSC's Avatar
Cams.
Hey guys, I have researched quite a bit and from what I can tell there aren't any cams available for us that actually make a decent amount of difference. I am making this post to see if my research is just full of fail, or to double check that there really isn't anything worth while for us.
I am rebuilding the motor July 13th and wouldn't mind tossing in a set of decent cams that are going to gain me something. I don't want to put them in if there not going to do much. Shed some light on this subject for me please, thanks guys.
Old Jul 3, 2009 | 09:39 PM
tityrous's Avatar
http://www.batesengineering.info/ call ray up and tell him what you want and he will tell you what you need to get and he machines everything and is very good on shipping!
Old Jul 3, 2009 | 09:44 PM
I will give him a call tomorrow and see what he has to say, thanks for the information .
Old Jul 4, 2009 | 09:02 AM
tityrous's Avatar
your welcome good luck
Old Jul 4, 2009 | 09:03 AM
Dayta's Avatar
iv got a set of 262 comp reground cams if your interested
Old Jul 4, 2009 | 09:05 AM
lsjwannabe's Avatar
All cams for the lsj are regrinds currently and have a smaller base circle then stock. This leads to the premature failure of lash adjusters. They could work with solid lifters iirc you would just need to get them machined properly.
Old Jul 4, 2009 | 11:39 AM
Once again sean comes in with the info =D, thanks bro. I think I am going to stay with the stockers for now. If anyone else has any information to add feel free.
Old Jul 4, 2009 | 11:44 AM
nicksredline's Avatar
from what ive heard cams are not worth the extra bump in power... unless ur going for every last drop of power u can get out of this motor.
Old Jul 4, 2009 | 11:45 AM
racehtecobalt's Avatar
good info
Old Jul 4, 2009 | 01:06 PM
2K5SS/SC?'s Avatar
BLE makes the solid lifters for the Ecotec. Just call them and order a set, but specify its for the the LSJ. They should drop right in a adjust just like a Honda's does!
Old Jul 5, 2009 | 12:16 AM
Angel's Avatar
I bought a set of steel cam blanks from Ray Bates with the hex uninstalled and he shipped them to comp for us to have them grounded with stock base circles. Gains should be fairly noticable. Hex will be pressed upon lining them up and pressing. No need for solid lifters this way.
Old Jul 5, 2009 | 01:09 AM
spike's Avatar
it will be cool 2 see this when its done
Old Jul 5, 2009 | 02:06 AM
2K5SS/SC?'s Avatar
What specs are you having the cams ground to? Very curious about this and would also like to know how much it will cost roughly for them when all is said and done.
Old Jul 5, 2009 | 04:10 AM
Angel's Avatar
The cam blanks cost $205/each and $35 for the hex. Comp is charging $125.75/each for grounding. As far as specs go I can remember right now. I have the specs down at my store and my memory isnt good enough for me to remember so Ill post them when I get there. I did go over our entire build with Chris Mays as this car has so many mods and alot of internal work in progress now.
Old Jul 5, 2009 | 09:44 AM
2K5SS/SC?'s Avatar
Sweet sounds good. I'll keep this info in mind then!
Old Jul 5, 2009 | 09:48 AM
subd for more info. What were the gmr cams like? Where they more power or just a broader powerband? I do not know much info on cams and this seems like a good place to ask questions and learn
Old Jul 5, 2009 | 10:47 AM
Jrhdpaintball's Avatar
goto areas thread about this cam research.. alot of info on hp and torque numbers
Old Jul 5, 2009 | 11:12 PM
Angel's Avatar
Everybody has there own opinon about number with cams yet many people also forget that you cant just go buy "performance" cams and expect to gain huge numbers. The way I am doing this imo is the best way whereas I am having custom blanks ground to suit the mods on my balt and therefore I will see much more gains because the cams will be grounded correctly for this application. Many people that claim that custom cams will/wont make much power increase must understand this. Cams are never something that you can add on correctly when you are extremely moded like I am. It is def a must to have them custom made.
Old Jul 5, 2009 | 11:13 PM
Angel's Avatar
Old Jul 7, 2009 | 02:38 AM
burntorange's Avatar
I am very interested as well, please post up your results and or specs when you get a chance. Thanks!
S1000rrsteve
Aug 24, 2015 02:00 PM
2000Firehawk
Mar 3, 2011 10:25 PM
Area47
Dec 21, 2007 05:18 PM
CSM Huber
Aug 22, 2007 10:56 AM
