car has no top end power
Old Mar 28, 2010 | 12:40 PM
06Stage2Cobalt's Avatar
So I can put the car in first and roast the tires, but I'm going to assume thats because of how short first is. Now, second usually slams me back in my seat (mods: injen intake w/ specter filter, CA header, cat back exhaust, 2.85" pulley, 60#s, OTTP Stage 2 tune, OTTP H/E). Lately it seems to not have any power. Cars I'd be able to walk all over beat me no problem. I raced a scion tc and barely won. Clearly something is wrong.
Last night I had a code for MAF performance issue or something, wish I could remember the code. I cleared it and continued driving. My thoughts right now are on a possibly clogged cat or bad maf. Anyone got any ideas?
I don't have an interceptor but on my ET97 scanner I'm seeing LTFTs of -17% (however short term is always close to zero). Once in a while I'll get a P0172 code (system too rich). I know ottps tune is rich but that seems abnormally high. Perhaps its running super rich and destroying the cat?
Old Mar 28, 2010 | 12:45 PM
madmark's Avatar
maybe a bad injector or maf
Old Mar 28, 2010 | 12:52 PM
anyone else know what LTFT their pulling running the OTTP S2 tune?
Old Mar 28, 2010 | 02:44 PM
JHans5774's Avatar
Are you producing more boost than normal?
Old Mar 28, 2010 | 05:35 PM
Not that I can see. I keep getting p0101 which is a maf performance
code. Possible maf?
Old Mar 28, 2010 | 05:41 PM
100% METH's Avatar
code. Possible maf?
doesnt seem like an issue with fuel trims
otherwise you'd throw the front o2 sensor code as well
Have you tried cleaning the maf or better yet, replacing it?
Old Mar 29, 2010 | 04:44 PM
BlackMagic's Avatar
I had this problem when I first got mine, for me it was my filter, it was caked with dirt and sand it was bad and mine would throw maf code when I would do pulls.
Old Mar 29, 2010 | 08:27 PM
johnladow07's Avatar
intercooler pump?
Old Mar 29, 2010 | 08:31 PM
1badBlueberrySC's Avatar
If you maf is bad it's going to cause the car to run super rich... or in your case 17% too rich...
Get your maf looked at or just clean it.
Old Mar 29, 2010 | 08:41 PM
OneCOLDBIZL272's Avatar
check vac lines for leaks, check bypass valve make sure its not cracked, check cat to make sure its not clogged, and clean you maf it never hurts to clean it with maf spray, if it were and injector it make a noice or you have a sputter when you speed up, also check to make sure you ic pump has not taken a crap and your intake temps arnt to high would casue big lose in power, but im going to say its the maf cat or bypass valve casue your running rich.
vjoel2011
Oct 2, 2015 12:11 PM
63 Nova SS
Sep 12, 2015 11:21 PM
bucks121
Sep 12, 2015 07:39 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
