Car Sputtering
Old Jan 28, 2008 | 07:16 AM
bwalker0510's Avatar
Car Sputtering
my car has started sputtering around 6000-6500 recently. i have a stage 2, airbox mod, and gm exhaust. i also get some knock from the engine every once ina while. i dont run my car hard very often and i only use 92 and 93(when i can find it). i thought it might be my converter but i replaced the dp recently with another stock one and it still does it. is it my spark plugs, i cant remember excatly what type but i know their ngk's.
Old Jan 28, 2008 | 08:27 AM
Rangerondubz's Avatar
I would check the plugs, or you could have just got some bad gas. What do you put in her?
RedEcotecSS's Avatar
in what gear? mines done the same thing in the top of 3rd i think it was. check your spark plugs also.
Old Jan 28, 2008 | 08:58 AM
it does it in all gears, its been doing it for a while a few hundred fill ups since it started lol. i fill up about every 3 days or so. and i only put 92 in it and 93 when i can find it. its doing the same thing it did last time i had to replace the dp, its just not as bad as it was.
Old Jan 28, 2008 | 09:26 AM
Hmmm it could be anything, fuel filter ect
Old Jan 28, 2008 | 09:44 AM
i guess its start replacing everything time lol, im at 31000 miles so i guess i need to bring out the savings account lol.
Old Jan 28, 2008 | 09:50 AM
Tigerballs's Avatar
Pretty sure it's your plugs. are they one step colder?
Old Jan 28, 2008 | 09:56 AM
cavy-to-SS's Avatar
its your spark plugs...i had the same problem no to long ago. just change them and you will be fine
Old Jan 28, 2008 | 10:00 AM
Onyxd04Redline's Avatar
Belt Slip?
Old Jan 28, 2008 | 10:05 AM
Fresh's Avatar
it could be a number of things. dirty gas, clogged injector, dirty fuel filter, spark plugs or wires. you can try running a few tanks of dry gas and/or fuel injector cleaner to see if it helps at all. might as well replace the fuel filter while you're at it. cheap n easy. new plugs are again cheap n easy.
Old Jan 28, 2008 | 10:23 AM
what spark plugs should i get i know ngk's but what part number anyone know. it didnt do it when i had autolites in it but it started a little while after i put the ngk's in it. any suggestions anyone please its driving me crazy.
Old Jan 28, 2008 | 10:25 AM
Tigerballs's Avatar
Bkr7e
Old Jan 28, 2008 | 10:27 AM
i think i had autolite xtremes in it before ad they worked fine.
Old Jan 28, 2008 | 10:35 AM
get NGK BKR7E's. They work wonders.
Old Jan 28, 2008 | 10:38 AM
Tigerballs's Avatar
well trial an error is the only way u'll know. ngk's one-step colder (BKR7E) are the plugs u should be running if i'm not mistaken.. If that doesn't help or if that's what ur running, try different plugs or gapping.
Old Jan 31, 2008 | 07:12 PM
well i got the plugs in today from CA wow only took 2 days to get them. car seems to be runnin fine now, havent driven it enough to figure out if that was the only problem.
Old Feb 1, 2008 | 07:39 AM
Maxim_X's Avatar
Def get the bkr7e. Gap below .40. I would get the coppers not the iridiums. They are cheaper and work more efficiently but don't quite last as long.. I would recommend setting the gap to .38.
Old Feb 1, 2008 | 07:41 AM
the ones i took out were bkr6e maybe thats why i was spitting at top end. drove all night with the bkr7e in and def so much better.
Old Feb 1, 2008 | 04:06 PM
rukkee's Avatar
I had this happen twice at the top of 2nd gear , it would hesitate for a sec then continue to pull to 7K . I dropped my SP gap from .40 to .33 and i hasn't happened since .
Old Feb 2, 2008 | 06:02 AM
Maxim_X's Avatar
.33 is too small. try .37.
Old Feb 2, 2008 | 02:08 PM
rukkee's Avatar
I tried all of them from .40 down to .30 , and for some odd reason the .33 idle's smooth and feel's the best for some reason . I know its tight , i just don't know why my car likes it so much .
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
