Car wont stop going rich
Old Jan 12, 2010 | 12:46 PM
InfraRedline's Avatar
I posted a thread a while back about how my car would randomly go rich under very slight load. It used to only happen once and a while but now when the car is warmed up it will sometimes do it maybe once a minute and sometimes every 3 seconds. It goes from stoich right down to like 13.5 or lower and on the scanner it shows a commanded 13.5 AFR when that happens. I just replaced the primary O2 sensor and it didnt help. I dont like driving the car like this since I have to let off the car so much and as you can imagine the fuel mileage **** the bed. If I go WOT it is just fine or anything above about 50% throttle I guess, but under light load it happens. Anyone hear of this happening or had it happen to them? Im really lost and would like to just be able to drive my car normal!
Thanks in advance
Old Jan 12, 2010 | 12:47 PM
rico's Avatar
damn man wtf thats weird hope u get it solved soon
Old Jan 12, 2010 | 12:53 PM
ml2242's Avatar
Something like that happened to me, found out it was a tuning issue and PE was set to be on at all times except idle fixing that fixed my problems
Old Jan 12, 2010 | 01:04 PM
Yeah me too man. Oh forgot to mention the 13.5 afr is converted to gasoline afr. Im not running that lean on E lol
Im thinkin maybe i should try tuning VE to see if that takes care of it. Maybe just under light load under 4k rpms or something
Last edited by InfraRedline; Jan 12, 2010 at 01:04 PM. Reason: Automerged Doublepost
Old Jan 12, 2010 | 01:58 PM
rico's Avatar
yeh true that do that and see what happens.. shoot u should look at my tune lol.
Old Jan 12, 2010 | 11:10 PM
No one else knows what this could be?
Rico, if you dont mind Id love to take a look at it. Especially the VE
Old Jan 13, 2010 | 01:00 AM
SSfamilywagon's Avatar
Hace you tried looking for an intake or exhaust leak.
Old Jan 13, 2010 | 08:22 AM
rico's Avatar
my current tune i need help with or my old e85 tune?
Old Jan 14, 2010 | 01:34 PM
Rico I thought you meant the old E85 tune.
Hmm i found an exhaust leak at the header and dp flange that I just fricken fixed before winter so that may have something to do with it. This cold weather makes my car **** the bed
Old Jan 15, 2010 | 01:23 AM
I had an intake leak and it was making my car rich at idle and wot. I just had to play with the couplers better
Old Jan 15, 2010 | 01:28 AM
100% METH's Avatar
I have the complete opposite issue
when in my normal maf based tune on 91 octane my car @ WOT pegs 10.0, but cruising the afrs are dandy.
I replaced the maf sensor, and still can't get wot maf dialed in. It's like it doesn't wanna listen!
Old Jan 15, 2010 | 04:32 PM
Hmm thats weird. My wot is perfect but slight load is messed up. It got better with a new sensor but not gone
Old Jan 20, 2010 | 12:36 PM
So today on startup it threw a P0135 and cruising it threw a P1133. It has thrown the 1133 before but not for a long time but before today I never saw the 0135
Old Jan 20, 2010 | 12:38 PM
rico's Avatar
atleast ur car starts...
Old Jan 20, 2010 | 01:08 PM
True...Hopefully all your problems will be solved with an ecu
Old Jan 20, 2010 | 02:49 PM
rico's Avatar
yeh thats if i find an 07 one. and not from a dealer cuz i know they try to rape me for it
Old Jan 22, 2010 | 01:29 PM
Well I still cant figure it out, the codes point to something with the O2 sensor, but i swapped that. So Im going to try swapping in my other MAF just for ***** and gigs to see if perhaps thats the reason
Old Jan 22, 2010 | 02:00 PM
rico's Avatar
damn hope that works
Old Oct 10, 2015 | 11:02 PM
Decepticon06ss/sc's Avatar
Any of these issues get
Solved?
Old Oct 12, 2015 | 10:40 AM
Man this is an old thread! Its a rear o2 sanity check. Need to leave the o2 sensor codes enabled but turn the MIL light off. The car will see that it has failed the check and moved on instead of continuing to try the check.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sean Cummings
Sep 11, 2015 09:35 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
