catless question
catless question
im wondering will i lose hp by hacking up a stock dp making it catless i know i prob wont gain any hp but im just wondering will i need a tune for it right away and wondering if im gonna lose hp anyone wanna help me out
no its not neccessary for a tune u would actually being freeing up alot of exhaust flow but if u already have a header and crap that has been tuned i wouldnt worry about it. atleast u wont have to worry about it getting clogged and causing excessive exhaust temps and backpressure.
yea man but the quality isnt that great for the sound my windows are up
http://www.youtube.com/watch?v=23ATPcPIPmo
maybe they were cracked alittle i can hear wind but it was like 35 degreess outside.
Last edited by wtpcobaltss; Jun 4, 2009 at 03:36 AM. Reason: Automerged Doublepost
get ride of the cat, it caused nothing but problems for me, it was throwing off my afrs and causing my car to lean up under wot, so i ended up turning off the cat over temp sensor so i could fine tune the afrs, a month later i just ended up getting a catless downpipe and i could be happier, i just used the catted pd for when inspection comes around
I took a long drill bit and just drilled my cat out. Worked like a charm. There really isnt any other way to do it unless you just completly cut the cat off. My car was significantly louder, and i could actually feel a little bit of a difference. I kept blowing them up with the factory stage 2 tune and pully. For the rear o2 go buy 2 spark plug anti foulers from autozone looks like a tube with a little hole in the middle and threaded on the outside. combine them and put it between your O2 and your pipe. that will keep your CEL off.
Last edited by stoon_cobalt_colby; Jun 4, 2009 at 01:08 PM. Reason: Automerged Doublepost
nice i got a megan muffler on stock piping right now i got silencer if i want it quiet i think for 50 bucks its worth a try
make sure you dont just gut the cat, its dyno proven that you lose a couple horse dude to turbulence caused by the inside of the guted cat, i rally didnt notice it being that much louder a little sharper, and i have three inch from the header back with a resonator
if i cut the whole cat out and replace it with new pipe i wont lose hp will it?
no you will actually gain some. by removing that restriction the exhaust gases can exit faster. low end torque might suffer some, but on the dyno mine really didnt. dont have dyno graphs on hand but i dynoed at 242hp/202tq with just catless and 212/201 stock.
z28addiction
Sep 28, 2015 12:03 AM
