catless vs High flow cat
Old Sep 1, 2009 | 05:29 PM
rcorona8's Avatar
My next mod is a dp but im still debating if to go with catless dp or high flow cat dp. My two concerns are if one will provide more power than the other or it does not matter? my second concern is will i pass smog emmisions with either catted or catless dp? or just keep my stock down pipe? Thanks
Old Sep 1, 2009 | 05:34 PM
umrdyldo's Avatar
No chance in hell you will pass any inspection.
Old Sep 1, 2009 | 05:36 PM
blackbolt89's Avatar
how about with a high flow. will i even pass.
Old Sep 1, 2009 | 05:56 PM
DTM2188's Avatar
Catless will not pass. High flow cats typically pass, thats your best bet if your worried about emissions.
Going cat less with an lsj doesnt warrant the minimal results (maybe +3-5hp), if it were the LNF different story, turbo cars + cat less = nice results.
Old Sep 1, 2009 | 06:01 PM
Jared B's Avatar
i always pass inspection without a cat
Old Sep 1, 2009 | 06:02 PM
Southtown57's Avatar
I don't know about other companies but Hahn states only a 5% difference in power between a catted dp and catless dp
Old Sep 1, 2009 | 06:16 PM
camaromanss1992's Avatar
i have basically the same mods as you. i did have a catless, but it was very raspy and actually i lost power, i had less boost and that lovely sc whine was gone. went highflow and got back the power, boost, and whine. plus without cat you will throw a CEL unless u get tuned and shut down rear o2 sensor. as if it will pass inspection or not, yes it will pass emissions, but if they look to see if you have a cat or not they will fail you.
Old Sep 1, 2009 | 06:19 PM
Karlen89's Avatar
I gained quite a bit of power when I went catless. No dyno proof :/
Old Sep 1, 2009 | 06:23 PM
it was seat of the pants dyno for me. i can say for sure i did lose boost and whine without cat.
pre dp-16psi
3" catless, header-14.5
3" catted, header- 15.5-16
Old Sep 1, 2009 | 06:24 PM
Jared B's Avatar
i never lost any power
Old Sep 1, 2009 | 06:27 PM
09turbo's Avatar
how do you do that?
Old Sep 1, 2009 | 06:29 PM
Jared B's Avatar
Originally Posted by 09turbo
how do you do that?
Got no check engine lights and i just put the stock muffler on.
Old Sep 1, 2009 | 11:05 PM
mrbelvedere's Avatar
when you get rid of a restristion you will loose boost but that is not a bad thing
Old Sep 2, 2009 | 11:10 AM
Razor564's Avatar
^^ Winner.
You just have to know which inspection stations don't check that kind of stuff
Old Sep 2, 2009 | 11:16 AM
umrdyldo's Avatar
You didn't lose power unless something was wrong. If you lost boost is was because your airflow went up. Which is a good thing. Unless you tested it, I doubt you lost any and in fact the gains were so unnoticable that you chalked it up as a loss in power.
Old Sep 2, 2009 | 12:52 PM
Texas SS's Avatar
Only fun thing with catless is the flame....
other than that its a pain if u cant find someone for inspection or hptuners
I replaced mine with Vibrants highflow cat but still throw 1 code
Old Sep 2, 2009 | 12:55 PM
ShortStack's Avatar
Very misinformed statement.
The boost increase your seeing is called RESTRICTION. Which is NOT GOOD.
You did not lose any power unless something else changed.. like the size of your exhaust.
Old Sep 2, 2009 | 05:36 PM
Look at it this way and engine is a air compressor the more air you can pump in and out the more power you will make
John
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
