Change 02 sensor now i have 2 codes on
Old Mar 17, 2009 | 02:10 PM
MadboostSS's Avatar
I replaced my o2 sensor today and now i have 2 codes on. there P0030 and P0134??? What is going on???? Help yall
Old Mar 17, 2009 | 02:27 PM
LopsidedJester's Avatar
which o2 sensor did you replace?
Old Mar 17, 2009 | 02:29 PM
TRANSAM197781's Avatar
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1) P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1) This may be a dumb question put did you plug it in incorrectly if the plug looks fine no messed up pins you may check youre fuses
Old Mar 17, 2009 | 02:46 PM
MadboostSS's Avatar
the upstream o2 sensor i replaced.
Yes i check it all out. but i bought the bosch o2 sensor. idk if thats bad or if i should return it and buy from the dealer
Old Mar 17, 2009 | 03:08 PM
did it have the plug on it or did you have to put it on
Old Mar 17, 2009 | 03:10 PM
MadboostSS's Avatar
Plug was already on it i paid 138 for it from advanced auto
Old Mar 17, 2009 | 03:13 PM
originaladrian's Avatar
you got ripped the **** off.
i just bought one from gmpd for 50
Old Mar 17, 2009 | 03:15 PM
I would check and make shure fuses first being the easiest. Then make shure its making contact at the plug as it should and also check and see if it came with a wiring diagram and make shure the correct wires are going where there supposed to . If all that checks out bring it back to advanced but it should work just aswell as the factory one .
Old Mar 17, 2009 | 03:23 PM
shadowfaxss's Avatar
Did you replace it because you had these codes in the first place?
Old Mar 17, 2009 | 03:25 PM
dsmlaser90's Avatar
lol i work at advance one is 130 and i just bought one from gm for 71
Old Mar 17, 2009 | 03:32 PM
Since you are not on-line as of this posting, the factory manual states that after you replace either HO2S you must perform a code clear with a scan tool regardless of whether or not a DTC is set. This is done to reset the HO2S resistance learned value and avoid possible HO2S faillure (warings and cautions page 0-7)
Old Mar 18, 2009 | 08:05 AM
MadboostSS's Avatar
i bought the one that hooks right up without having to deal with cutting the wires and stuff
I replaced it because i had a CEL on that said it was no good. i think it was P0104 but i cant remember.
Last edited by MadboostSS; Mar 18, 2009 at 08:05 AM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 12:56 PM
P0104 Mass or Volume Air Flow Circuit Intermittent i dont think that was the code lol but anywho any luck on tracing the problem
Old Mar 18, 2009 | 12:58 PM
RedEcotecSS's Avatar
check your EMS or EXH fuse under the hood. it's a 10amp fuse. Could be popped. I'm almost sure this will fix the problem.
Old Mar 18, 2009 | 01:57 PM
MadboostSS's Avatar
Yall know something.
I just took out the sensor i bought from advance auto and the damn thing was black as FFFFF after one day.
But the old one thats no good was clean of that black ****. i took it back out after driving it all day and it was stick clean.
Yall think its the shitty advance one? It was a bosch sensor lol. So i returned it and bought one from gm and hopefully this will fixed all my problems..... I check the fuse yall are talking about and its still good.
Old Mar 18, 2009 | 08:43 PM
bbbevans89's Avatar
Lol Never Buy That Bosch **** I Bought One For Bank 2 And I Threw More Codes Than My Stock One Did And It Was Cut In Half. The Gm One Will Work For You I Had To Buy An Ac Delco One Off Here Used And It Works Great.
Old Mar 18, 2009 | 09:05 PM
EUGENIO's Avatar
dam i'm glad you did this thread now i know what to do ,i was haveing the same thing happening to me.
Old Mar 19, 2009 | 02:33 AM
dsmlaser90's Avatar
so i bought an acdelco one for my upstream as well and my cel is back on too lol
Old Mar 19, 2009 | 10:56 AM
MadboostSS's Avatar
I bought the gm one yesterday put it in and unpluged my battery for 10 minutes and drove around for alittle while and the codes back up again. dont know what to do
Old Mar 19, 2009 | 10:58 AM
if you said that fuse i told you to check is good then i'm at a loss... no idea...
Old Mar 19, 2009 | 10:59 AM
MadboostSS's Avatar
I dont know whats going on man with yours and mine and whoever else is having the same problem
I have no idea what to dooooo
Old Mar 19, 2009 | 11:02 AM
MadboostSS's Avatar
Is the fuse under the hood or is it in the car or on the floor on the passenger side?
Last edited by MadboostSS; Mar 19, 2009 at 11:02 AM. Reason: Automerged Doublepost
Old Mar 19, 2009 | 11:29 AM
dsmlaser90's Avatar
actualy mine came on for the rear p0420, i usd the antifowler and it worked for about a week then went away
Old Mar 19, 2009 | 11:40 AM
MadboostSS's Avatar
I checked that fuse you were talking about and its still good. i took it out and turned it around and see if that might have fixed the problem. but idk
Old Mar 19, 2009 | 11:45 AM
That won't make a difference
