check engine
Old Mar 25, 2009 | 07:50 PM
timhebert's Avatar
check engine
my check engine light keeps coming on and when i put the code reader to it, it says misfire on cylinder 4. i have the ott stage one kit in it. It comes wiht 60lb injectors and 2.8 pulley, if anyone knows how to fix this let me know
Old Mar 25, 2009 | 08:05 PM
TRANSAM197781's Avatar
Did you talk to ott im shure they will be more than willing to help you
Old Mar 25, 2009 | 08:10 PM
timhebert's Avatar
not yet was waiting to see if anyone had this problem first.
Old Mar 25, 2009 | 08:29 PM
how long have you been running the kit before you had the problem
Old Mar 25, 2009 | 08:33 PM
timhebert's Avatar
week or two. seems to only do it when i'm sitting somewhere and its running. after my cars is off for ten minutes it goes off.
Old Mar 25, 2009 | 08:35 PM
zrated89's Avatar
check the number four plug are you running a one step colder? or stockers
Old Mar 25, 2009 | 08:38 PM
yeah i would double check youre plug
Old Mar 25, 2009 | 08:59 PM
timhebert's Avatar
i have. i'm running one step colder gaped at 35
Old Mar 26, 2009 | 12:32 AM
rico's Avatar
so u getting the p0300 code?
Old Mar 26, 2009 | 12:53 AM
Sharkey's Avatar
p0300 is random cylinder misfire. p0304 would be cylinder 4.
yea, check your plugs. i myself run .038" gap on ngk bkr7e plugs without issues.
Old Mar 27, 2009 | 06:14 PM
korbar22's Avatar
I also have a tuned PCM from OTTP and I put it in today and drive home and my engine light comes on and It is a P0304 misfire cylinder 4.... What could it be?
Old Mar 27, 2009 | 06:31 PM
zrated89's Avatar
same secnario check your plug
Old Mar 27, 2009 | 06:33 PM
Black SS/SC 06's Avatar
Did you guys do a case relearn when you installed the kit?
Old Mar 27, 2009 | 09:13 PM
korbar22's Avatar
ya theft and crank relearn... came on I erased it and then drove for about half and hour... I'm still on stock plugs and NGK 1step are on there way
Old Mar 27, 2009 | 10:05 PM
Dainslaif's Avatar
Could be the plugs, but it's weird that it's just the one cylinder like that. It happens when it's running, not just at idle, right?
Old Mar 28, 2009 | 03:15 PM
korbar22's Avatar
no it only comes one when its idleing, happened again today... WTF dont want to hurt it
Old Mar 28, 2009 | 03:58 PM
Dainslaif's Avatar
Try swapping the coil packs around then the plugs and see if the code follows. If it doesn't follow it's likely the tune. I run 1 step colder plugs at .035 and I used to throw a P0300 if I idled for like 2 minutes. Retuned the car and haven't had a CEL in a while.
It's a 60# injector + idle thing.
Old Mar 28, 2009 | 04:00 PM
rico's Avatar
well u need to do whatever lil tune changer on mines so i dont get that damn light on again haha
Old Mar 28, 2009 | 08:25 PM
korbar22's Avatar
ya ok I try that... thanks for the help
Old Apr 5, 2009 | 01:52 PM
korbar22's Avatar
Ok so I put my ngk one step plugs and gap at .35 and I moved all the coil packs around and still getting P0304... Eny ideas's? Happened after I installed 60's and ott tuned pcm
Old Apr 6, 2009 | 12:10 PM
korbar22's Avatar
Old Apr 6, 2009 | 12:57 PM
Dainslaif's Avatar
It's a known issue with 60s. Contact OTTP and see if they can help you out.
What pulley are you running? If you're on a 2.8 or larger I'd say try regapping to .036-.037
Old Apr 6, 2009 | 01:53 PM
flash13brandon's Avatar
Check the O-rings on the injector and the injector seat or w/e it's called. Make sure it isn't cracked or anything.
Old Apr 6, 2009 | 02:01 PM
JimzSS's Avatar
^^^^check your injectors/#4
swap it like you did the plugs/coil.
60s aren't the easiest to tune at idle.
Old Apr 6, 2009 | 07:27 PM
korbar22's Avatar
I e-mailed them and he said to check the plugs(brand new just put them in), swap coil packs(did that), swap injectors (have yet to do that), or a compression test.. what will that test tell me, the car was running fine before I put the pcm in my car it only has 21000kms on it I think it is the tune but the shitty thing is that I dont know a local tuner so I am pulling my hair out on this one... I am also running the stage 3 pulley 2.99
If i have gapped my plugs at .35 is it possible to gap them larger now?
Thanks
