clutch failing
clutch failing
So as the title states my clutch is failing, and I just wanted input on a replacement. Also I think that the slave cylinder might be going too as my pedal gets excessively stiff with little travel, especially after a hard pull. Any info or suggestions would be awesome thanks
Recent topic just yesterday...
https://www.cobaltss.net/forums/08-1...asters-281542/
Winner is KY Clutch, best price, best quality, best performance.
Stage 3 is what everyone gets. They are on www.TurboTechRacing.com
We sell them, and ask if you want one when you purchase the KY clutch kit, optional to purchase, but recommended. Order VERY soon and it can ship yet today.
Hey,
I had similar issues with my clutch.
Bleeding the fluid and flushing and replaceing the Fluid helped with the stiffness after a hard pull, but didnt fix the engagment issue I was having. My Spec Clutch was worn all the way down, and I had a leaking Elbow fitting. I had a GMPP Clutch installed. It came with the LNF TOB wich also doubles as the slave cylinder. So Def get the TOB/Slave, as well as the clutch pipe replaced.
My Clutch is good to go now.
If you go GMPP the LNF TOB comes with it...
If you don,t Defently get the LNF TOB
I have an extra one since I didnt know my GMPP would come with one.
I believe you will need a tune if you get a lighter flywheel. That's the only reason why I didn't do it when I did my clutch. I'm pretty happy with the GMPP clutch and PP w/ LNF TOB/slave.
You dont need a "tune" not sure why anyone would ever stated you need a "tune" if you have a light weight flywheel.
on an engine that already has a rough idle like the lsj, lightening the flywheel will only make it worse, and you might get some misfire codes. Typically the idle is raised in the tune to compensate.
Mine had a lighter flywheel on it. I didnt know it till they pulled my clutch out. Now with my LSJ flywheel the idle is alot smoother, and the engine revs alot smoother now too..
Let me know if you want my aftermarket one, I think its in good shape sitll If interested I can take pics of it.
That's the same thing I was thinking, I had never heard of tuning for a flywheel, the most I had heard of was a lighter harmonic balancer to compensate for the lower weight.
Thanks man. Im going to order the KY Stage 3 kit with the LNF TOB... just saw the six speed conversion kit though.... wonder how pissed the gf would be if I accidentally spent $3900 out of our saving account...
