Clutch Slipping
Clutch Slipping
I have 7500 miles on my 07 ss/sc and i think the clutch is going bad. i throttle on the car in 1st and banged 2nd and it jumped right to rev limiter so i let off the gas. when i got to my house all i could smell was clutch. did anybody else have their clutch start go bad with hardly any miles on them. I have the GM stage 2 kit. is that more power than what the stock can handle? I have the 100,000 mile warranty with the car. GM should cover the costs right?
i'm having the same problem. it only happens if i wind out first and try to shift fast to second. i've only been to the track once and my only mod is an injen intake. i'll have to replace the intake and take it into the dealer to see if they'll cover it
Getting the clutch covered under warrenty will be tough. I think a few people on the forum have been lucky enough, but most have not. You may be S.O.L.
Depends on your relationship with your dealer. So a search, there have been some really good threads on this topic. You'll find some good help there.
You won't get a clutch covered under warranty...so go clutch shopping, and stop beating on the car.....I have 26500 miles on my clutch, 2.5 pullied, all bolt ons, 100 octane (been 2.5 pullied for about 10-11,000 miles), and shes showing wear but probably not close to slipping
when i was cruising last night something similiar to this happend to me. i, too, rode 1st gear to about 6000RPMs and tryed to shift fast into 2nd and it just hit the rev limiter so i went and parked it cause it freaked me out and all i could smell was clutch. i guess i gotta be more careful... haha
just because every once and in a blue moon i jump on the throttle to enjoy my car does not mean i beat my car. im sure everyone in here drives their car aggressive sometimes.
Yeah around 500-600....Try not to go to a dealer...they might charge a LOT more....I was quoted $800 at my dealer.....So yeah anywhere between 500-600 is good, try to bargain with them too
oh well, now you just have an excuse to get a better one, right?
Last edited by Johnboy12358; 03-25-2007 at 11:05 PM. Reason: Automerged Doublepost
i dont have the money right now to spend 1000 or more on a clutch and install. i just got my JBP Vortex header, downpipe, intake, SSC springs and new wheels so the credit card is still smoking from that. I will see if they will cover it and if not drive it to it is totally ****. it seems fine under normal driving.
I don't race my car but my clutch has slipped since about 9K I'm at 17K took it to the dealership a few weeks ago. They accused me of drifting and racing my car and acknowledged that the clutch does slip after multiple accelerations and left it at that. So good luck getting the dealership to cover anything. I haven't been hard on my car at all and they don't want to cover anything.
going through the same thing over here.... cyncros bad in 2nd so gm gives me a new tranny ok so thats cool then a week later got on it a little bit hehe, and stop b/c the clutch started to slip??? all i could smell was clutch dam.... then the tranny starts whinning just great.. take it in and(i used to work there so the hook me up) and they say ok we'll get u another tranny and hopefully my body can hook it up with a new clutch if needed. but i come to find that these saab clutches are crap on top of crap so i think when i start throwin on mods it will be a good idea to get a act or exedy clutch??
Buddy sry
Last edited by DressBoyBlues; 03-26-2007 at 12:08 AM. Reason: Automerged Doublepost
Only about 2 days if you do it yourself. I started Saturday night around 8, worked till 2, then started the next day around 2-midnight. All that is left is bolting on a couple more things and bleeding it, about another hour, hour and a half left. Then once I make sure everything is good and solid, time to put on my hurst shifter, and drive around some more. If I have time the HE will be going on too.
look below...thats a fair estimate. I had mine installed for $585
No problems jumping on the car, just try doing it from second on. It doesn't seem to like first gear very much, a lot of power, a little traction(or alot of wheelhop), and a short-as-**** gear mixed with a clutch that isn't top-notch just says problems. You're not the only one, lots of people have these problems. Personally I just wouldn't punch it in first (or at least let off at around 4k not 6k) if I intend on keeping the car healthy after the stuff I have seen happen here on the forums.
Doc makes all the right points. Talking with a lot of the SS/SC owners in this area we've come to the conclusion that a lot of the people with slipping issues may be beating on their cars. Not to say that you are beating your car necessarily, but I think some well-conceived car-care will extend the life of these clutches. When people use language like "launching" it gives the impression that you're hard on your car.
I had the same problem about 3000 miles and if i got aggresive with 1 to 2nd shift it would slip. took it to the dealer they reimbursed me for the stock clutch and did a free install on my spec stage 2+ they told me it was nothing i did wrong. GM Tech says the recommend use of a performance clutch with stage 2, told the dealer the stock unit doesn't have the clamping force for it. BUT you know some people here will insist i don't know how to drive.
