Cobalt Addiction Stage Kits
Those sound like crank hp numbers. But still good nonetheless. I already have all kinds of mods on my car already and have some more coming in the mail. However, i'm willing to drive there to get my pcm tuned.
Oh, one more thing, could they install a clutch? And if so, how much would it run me?
Originally Posted by vandy0419
What kind of tuning are you doing then? Everyone else I know is able to get their injectors around 85%+ with a 2.8" pulley...I think with 60s and a 2.5" Dan is running high duty cycle...
like 72% iirc
They use hp tuners... I was gonna data log some runs this week.. but low and behold my clutch gave out on me so that'll have to wait... we have one car we might try friday night to play with inj duty % but from what we've seen they haven't been that high...
Originally Posted by djt81185
like 72% iirc
Also, what #s are you going by when they say the hp gain...because 90hp gain means to me around 300+ because I really don't know many LSJs that aren't underrated. GM says 205 stock, which in reality is underrated and most are getting 210+ stock...
Do they offer a machined snout or a tool to machine the snout with for the 2.5"? I know 2.6s will fit somewhat from ZZP without machining the snout...I hear you still have to file it a little...
Originally Posted by 06blackg85ss
probably a typo... but with our testin on my car and 2 others... we maxed at 54% with a 2.6 pulley, intake and 42.5 inj... 60 lber are only at 34% with intake , header, exhaust, meth, and 2.6... have to do a run when I get my car back with the 2.55 pulley... I should have some log runs I can post up tonight when I get home...
Well most of the cars that are getting work from CA just recently blown up. I belive 3 of them that went to the track a couple days ago with 2 of them breaking axles and 1 blowign a trans. So that would explain the delay of the dyno #'s
Thats part of the plan... (we're working on a guy for axles.. and he should have his clutch out soon). which I should have installed
speaking of IDC.. how do you log yours..
and our cars broke because of how sticky the track was and the amount of power they put out... we walked the track that night and it ripped our shoes off... all they way to the 1/8 mile,.,, there was a 8.50 index class that ran sunday cause the event was rained out thurs... so they prepped the **** outta the track... hey gotta pay to play guys... I was going for at least a high 12 sec pass and didn't even make it to the line. well I'm sending a spare tranny out to have the gears hardened and when its back together I shouldn't have any more problems (until the turbo kit is done)
And I have a config file for HPT I can send you. I have asked for yours a few times. I just would like to see the differences and why your results are so far off every other cobalt that logs.
I'll send you tonight... I don't have any of the new ones though... I should be at the shop friday though... sorry man ... just been doing so much work lately I forget about alot of things...
If you want to hit up a sticky track I hope you have an upgraded clutch and axles... or you will get owned by the traction...
the axles on these cars also suck...paul is right though it was due to the track conditions not anything CA did...also we usually dont do installs on the local guys cars, we do tune however ...all of the locals are pretty handy guys and know how to install and most do their own work or help one another out....but neither contributed to anyones cars breaking this weekend.
I want to make that perfectly clear.... there are no malfunctions with any of the parts that we provide, it merely was a shitty week at the track resulting in the breakdown of stock GM parts.
from what we've seen yes... but I wil retest this weekend with different settings from patathss... maybe that was the problem/// but I"ve only seen safe afr (12.4 or so) with that setup with no spikes so it should be cool...
and as Donna said... nothing I got from C/A broke... just my stock GM shitty parts, axle is weak as ****.. I could probably snap it by hand... and exploded clutch (still don't know how that happened) and it exited the top of my tranny soo... just waiting to see how extensive the damage was.
I've been playing with the idea of switching to the 4.45 ratio that the cup car uses
Here's a cobalt ss with a 7000 rpm rev limiter
http://www.car-videos.net/tools/spee...B1=Recalculate
Here are the speeds for a 7000 rpm rev limit and 4.45 gears
I don't know if the above links worked, but on stock ratios and 7000 rev limit, it achieves 36.4 mph
With 4.45 gears and 7000 rev lmiit, 1st gear achieves 33.1 mph. That's low and will suck for launching. We just need to get a good tranny swap going.
