Cobalt ARP Flywheel Bolts
Here’s a ARP bolt that I cross referenced that will work with cobalt SS Flywheels aftermarket, or stock.
Part # 203-2802. (Part doesn't say for cobalt but, they will work for a flywheel on a cobalt SS) not sure if they will work with a 2.2 or 2.4, For I don't have a crank of either to test with.
They have worked great for me, I hope others can use this part as well, like I have.
Here’s two pic’s
Here’s two pic’s
Summitracing has them for 30 bucks.
http://www.summitracing.com/parts/ARP-203-2802/
stock is stretch bolts and expensive, more pricey than arp. If anybody has put these on a lnf flywheel and know they hit the clutch disc? If so Will grinding them down fix the problem. Bc i'll do it. Beltsander style. If not then i'll buy them anyhow do it then chime in if it works.
Plus so many degrees. They are torque to yeild.
I have not but I have them in my car right now, and have not had an issue. I am running a clutchmasters clutch.
Last edited by cmiller8006; Jul 4, 2011 at 07:08 PM. Reason: Automerged Doublepost
I know this is kinda old, but i just tried using these with an Exedy stage 3 Hypersingle Clutch/Flywheel kit and The heads are too large and rub against the inner part of the friction plate. I believe the stock flywheel would have been deep enough to work correctly though.
I'm on spec flywheel, with spec stg3 plus super clamp. Didn't rub for me but, they did for my buddy as well we just had them milled down a smidge. P.s. I couldn't edit the original post
hmm, glad i found this. i just installed 203-2802's on my lsj with ky stg3 and stock flywheel and have a mysterious chatter when the clutch is disengaged. however performance and feel are uneffected. i'll have to check this and get back to you guys.
