Cobalt sounds like machine gun
Old Apr 3, 2008 | 08:23 AM
silentd's Avatar
Alright guys i have a problem. The other day whenever i would get near redline (5500-7200) my car would sound like a machine gun popping. Now all my mods are in my sig and a stock ss/sc with just intake exhaust was able to keep up/ win by a fender. Im not sure what it could be so any ideas would be great.
also i pulled my spark plugs let me know what you guys think. its in order from left to right I am running 2 step colder plugs, and the plugs smelled slightly like oil
after i pulled the plugs and put them back in it seemed to be ok again, but for how long who knows
Old Apr 3, 2008 | 08:26 AM
cobalt_driver's Avatar
did it smell like rotten eggs? mighta been the catalytic converter. but a machine gun noise? hmmmm....u got me on that. how rich are u running? mighta been a backfire?
Old Apr 3, 2008 | 08:28 AM
BOOSSTED 06's Avatar
im going with blown(clogged) cat and it looks like you got some detonation going on
i see a window switch, you have nitrous?
do you have a scan gauge, are you seeing any knock
Last edited by BOOSSTED 06; Apr 3, 2008 at 08:28 AM. Reason: Automerged Doublepost
Old Apr 3, 2008 | 08:30 AM
thats the only thing i cud think of.
Old Apr 3, 2008 | 08:33 AM
silentd's Avatar
yep i do have it scanned too... NO knock... Nitrious has not been used EVER. it is in the process of being wired correctly. NO rotten egg smell or any smells. I am running rich (i have a wideband) WOT from 4 - 7200 goes from 10-11.2
Wideband is NOT hooked up to laptop
im also running a high flow cat and just got the wideband installed last week. they also replaced a gasket because of a leak. they didnt say anything about the cat
Vibrant Header/DP, Corsa Touring catback
who tuned your car?
Old Apr 3, 2008 | 08:34 AM
silentd's Avatar
stage 2 tune.... it hasnt been tuned yet
Old Apr 3, 2008 | 08:35 AM
the dealer installed? did they put the iridium plugs in?
or are those platinums, if so did they put those in?
Last edited by BOOSSTED 06; Apr 3, 2008 at 08:35 AM. Reason: Automerged Doublepost
Old Apr 3, 2008 | 08:37 AM
silentd's Avatar
Yes dealer installed stage 2 and dual pass
They are the NGK iridium 2 range colder. I put those in gapped to .40
Old Apr 3, 2008 | 08:38 AM
k, thats a little far of a coldness range for just stage 2, try installing the $2 coppers and see how the car acts first, then go from there
ngk-bkr7e
Old Apr 3, 2008 | 08:43 AM
silentd's Avatar
actually im not sure what i gapped them to, it was either .40 or .42
ngk-bkr7e
I thought i would run the colder ones since im gonig to be spraying (50 wet)
ill run to autozone tonight and try them
Also what should i gap them at? start at .40 and work my way down?
Old Apr 3, 2008 | 08:48 AM
yeah try a few gaps until you find one that your car likes
Old Apr 3, 2008 | 11:20 AM
silentd's Avatar
bumpity
Old Apr 3, 2008 | 03:29 PM
suprchged's Avatar
stock plugs ftw my car ran better with the stockers than the coppers
Old Apr 3, 2008 | 03:43 PM
invisible's Avatar
Oh yea, well mine ran like **** before I put coppers in.
Old Apr 3, 2008 | 03:46 PM
sick06cobalt's Avatar
sounds like a few things definatly try the coppers...
but from what it sounds like is that your cat is fried.. maybe clogged.... how long did you break it in for when you put it on?
Old Apr 3, 2008 | 03:50 PM
D4u2s0t's Avatar
that's a pretty big gap. .42 is way too big. and why 2 steps colder?
SS33's Avatar
2 stages is too cold for stage 2 only. 2 stages colder isn't needed until you drop quite a bit further in pulley size
On stage 2 my car loved the stock plugs,
when I dropped to the 2.8" pulley I went with BKR7E's gapped at .038 and she is very happy. Switch up to stock or 1 stage colder, your motor will thank you
Old Apr 3, 2008 | 04:20 PM
silentd's Avatar
i went 2 colder because i was going to shoot a dry shot. well that changed to a wet, and as for breaking it in, i cant say i really did lol. a clogged cat would make alot of sense, because i just got a gasket replaced and it sounds like its leaking again, no more then a week later..
**** it, straight pipe here i come
The Rookie24
Jan 20, 2016 05:14 PM
Sean Cummings
Sep 11, 2015 09:35 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
TurboWood
Sep 7, 2015 11:08 AM
medic710
Sep 6, 2015 08:53 PM
