Cobalt ss 2007 help
Old Jan 31, 2015 | 04:27 PM
nixiee_cobaltss's Avatar
Cobalt ss 2007 help
Hi my name is nixie and I have 2007 supercharged cobalt ss, I live in colorado. I just have the k&n intake right now and I love it with a catback exhaust. I'm trying to get the borla exhaust cause the one I have now just sounds like a riced out Honda and then plan on the stage 3 kit but I am not sure if the zzp or the gm is better?? I heard good and bad things from both. I also plan on spraying 50 shot of nos or running e85 any suggestions?
Old Jan 31, 2015 | 05:29 PM
NikeTapia3's Avatar
I personally have the zzp stage 3 kit and I love it. Really wakes the car up. And I think the gm stage 3 requires AC removal while the zzp stage 3 doesn't. I would strongly recommend the pcm that is offered with the zzp stage 3 kit
Old Jan 31, 2015 | 08:41 PM
09CobaltSS1's Avatar
The zzp stage 3 and gm stage 3 are 2 completely different animals. Everything from the physical pcm itself down to the parts involved are completely different. Do some research on the two setups first op, as there is quite a bit out there to be found, and make an educated decision from there.
Old Feb 6, 2015 | 06:53 PM
tomj77's Avatar
Why is this in the dyno forum
Old Feb 7, 2015 | 04:12 AM
andrewcarr1993's Avatar
You can't run E85 on the GMS3, go ZZP, 80# injectors. Just stick with their S2 kit and get a small pulley that add on HE doesn't do much.
Old Feb 7, 2015 | 08:21 AM
mrbelvedere's Avatar
this has been covered use the search button and educate yourself
brandon04
Sep 25, 2015 08:16 PM
Regalgs
Sep 17, 2015 02:27 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Adam144
Sep 3, 2015 07:48 PM
