colder plug make a difference?
Old May 11, 2008 | 05:21 PM
Inferno's Avatar
step 1, step 2 ect.
also what r most people runing?.
Old May 11, 2008 | 06:10 PM
SJSchafer's Avatar
Originally Posted by Inferno
step 1, step 2 ect.
lol. Didn't like my answer?
most people who pulley down from stage 2 (2.8-2.9) are running NGK BRK7E plugs. I personally like the copper.
Old May 11, 2008 | 07:40 PM
INFE's Avatar
our cars come with iridium why would you put shity copper plugs in our car..............
Old May 11, 2008 | 07:44 PM
anthonyS88's Avatar
Old May 11, 2008 | 07:45 PM
BriantheLion26's Avatar
I'm pretty sure stockers are platinum. Plus I was always told copper is good for boost. Iridium works too they are just a lot more to buy but will last longer as well. I have the bkr7e's in right now on a 2.9" and they seem to be working just fine.
Old May 11, 2008 | 07:48 PM
SJSchafer's Avatar
lol. Copper doesn't last as long, but is a better conducter of electricity, so has a better spark.
Old May 11, 2008 | 07:59 PM
INFE's Avatar
By the way the are IRIDIUM
Old May 11, 2008 | 08:53 PM
TommySSSC's Avatar
"colder plugs" just means the gap of the plug. i was running the bkr7es with my 2.9 and i was fine. since i switched to 60s and 2.6, im occasionally getting a little knock at 5500 rpms, i just think i should get new plugs (i put about 30k on them so far)
Old May 11, 2008 | 11:51 PM
SJSchafer's Avatar
Colder plugs does not mean the gap. It is the heat range.
The temperature of the spark plug's firing end must be kept low enough to prevent pre-ignition, but high enough to prevent fouling. This is called "Thermal Performance", and is
determined by the heat range selected.
It's important to remember spark plugs do not create heat, they only remove heat. The spark plug works as a heat exchanger
by pulling unwanted thermal energy away from the combustion chamber, and transferring the heat to the engine's cooling
system. The heat range is defined as a plug's ability to
dissipate heat.
The rate of heat transfer is determined by:
The insulator nose length
Gas volume around the insulator nose
The materials/construction of the center electrode and porcelain insulator
Old May 11, 2008 | 11:56 PM
anthonyS88's Avatar
just a little something
After i got stage 2 on my car at like 2k miles, about a week later my stock platinum plugs were fried, i replaced them with some new ones i had laying around my house and a week later they got fried also (car was misfiring hard) I went and bought the ngk bk7re copper plugs, and since 2500 miles im now at almost 16k I have had no problem with the same set of copper plugs.
even if i have to change them once a year (which i dont think i'll have to), it only cost me 8 dollars for 4 plugs which is fine by me.
Last edited by anthonyS88; May 11, 2008 at 11:56 PM. Reason: Automerged Doublepost
Old May 11, 2008 | 11:57 PM
SJSchafer's Avatar
Your plugs fried from preignition. Colder plugs ftw.
Old May 11, 2008 | 11:58 PM
InfinityzeN's Avatar
BTW, your wrong. The stock plugs are platinum.
Since you have iridium plugs, then they shouldn't be going bad. However, I would suggest going 2 steps colder then stock with that 2.6" pulley.
Old May 12, 2008 | 12:02 AM
anthonyS88's Avatar
exactly my point... Colder plugs FTW. I keep telling my friend that who owns a GS-T eclipse who blows a 25 dollar set of bosh platinum plugs every month
Old May 12, 2008 | 12:04 AM
SJSchafer's Avatar
and as long as I am here the stock plugs are
NGK PFR6T-10G "Laser" Platinum *STOCK heat range*
Google is your friend.
lol. That's funny right there, I don't care who you are!!
Old May 12, 2008 | 12:05 AM
anthonyS88's Avatar
you would think that someone with a few thousand dollars of work into that motor and boosting it to about 20psi would know a little about spark plugs
Old May 12, 2008 | 12:07 AM
SJSchafer's Avatar
Hell, I just grabbed the stock plugs I pulled out of my 07 when I went colder and googled the part number. lol
Old May 12, 2008 | 12:24 AM
Action Jack's Avatar
I just picked up some of the bkre7 IX and they are working out great so far, way better than the bkre7 r's I was running. The only thing that I could complain about is, I snapped one of the plugs tips when trying to gap it. So I had to go by another one, later I found out you're not suppose to gap the iridium because the tips are so delicate.
Oh well I gapped them at .35 and everything seem fine.
Old May 12, 2008 | 11:07 AM
n8g's Avatar
n8g
Plugs were not even on my list of things to do. I'm about to go to a 2.85. I guess I should get 1 step colder plugs?
Old May 12, 2008 | 11:16 AM
LamboW9's Avatar
if you buy a stage kit most kits come with a range or two colder anyway..whether they are autolites or ngk's
Old May 12, 2008 | 11:17 AM
SJSchafer's Avatar
I would.
Area47's Avatar
Rent me! per hour
because some of us know what we are doing.
Old May 12, 2008 | 11:18 AM
SJSchafer's Avatar
rofl
Old May 12, 2008 | 11:21 AM
Area47's Avatar
Rent me! per hour
rofl
kekekekekke
i have no desire to explain why.
Old May 12, 2008 | 04:25 PM
TommySSSC's Avatar
area 47 always has come kind of smart remark no hard feelings, plus wicked tunes me
Old May 12, 2008 | 05:23 PM
Brian's07SS's Avatar
Stage2 Kit didnt come with any plugs..
