Compression numbers, am I safe to go turbo or rebuild motor first?
Hello, new to the site this is my first time posting anything. I just wanted to know if my compression numbers are good cause I want to go turbo for more power.
heres a pic of the numbers the shop got when tested
the compression numbers show your more than 15% variance between cylinders, anything more than 10% is considered bad. the lead down of 23% is terrible, and the note indicating its coming out the vent on the valve cover indicates bad rings.
its toast, time for a rebuild before you cause serious damage.
Numbers aren't bad but cylinder 4 looks a little low compared to the highest one.
the numbers are not good, well some of them are. Like sharkey said cylinder 4 is shot, looking like bad rings... add boost to that and it won't be long before he posts asking where to find a fresh LSJ or looking for rebuild info.
lsj block is a better choice and stronger but in all reality i would just run you cant hurt it much more then it is now
Wait, the stock lsj block is stronger than a gen 3 block? But I also wanted it to last since I heard the gen 3 is more reinforced and better for higher hp
the stock block record is 585hp and that would be crank rods and pistons
