cooling...
cooling...
Sooooo I found out that i have REALLY small pully.... its a zzp 2.6 not a 2.7 i didnt look at it for a few days lol till REDFOCZ looked at it lol i completely stock cooling and my computer is blocking him even connecting to it to datalog...iam worried...help!?!
He bought his car used that way.
Sean what do you mean it's blocked?
The person who put the tune on lock the computer you mean? or is the OBD II port broken?
Also yes if your on stock cooling get that 2.6 of immediately!
Go get a stage 2 pulley or Nate's 2.9.
You need cooling mods and on a 2.6 I believe your over spinning the Supercharger which might be another part of your problem.
Sounds like you need to figure out what the hell was done to your car. See if the dealer you bought it from can get you contact info for the previous owner and see what the scoop is.
And again get off that 2.6 it will blow your number 4 piston if left on with no cooling mods.
Let me know what you find out.
just read your sig)
What you need to do is find out what injectors you have on the car first. Very easy to tell if they are 60's or GM's 42/36# injectors. Then you need to let us know if the OBD2 port is not working, i.e. the fuse is burnt out, or if the PCM is indeed locked. Definitely don't boost it until then.
If you do have 60's obviously your car is tuned for them somewhat. Hook up a wideband to see what the A/F ratios are like and also see if you have a dual pass plate installed while you're at it. If not get one. You may have some free mods that you can use to your benefit here.
It will be the 15A blue fuse on the left side of the black fuse box labeled "LTR" if I remember correctly. This will allow you to hook up HPTuners to the car if it cannot connect properly.
the ltr fuse looked good.. my cig lighters work cause i got my phone Charger and radar hooked up to both. i just got back from the dealer an i have an apointment (i cant spell loll) tomarrow i told them i threw a code lol i also asked them for the origanal owners number...
