Cooling Issue..
Cooling Issue..
Ok, so my car has been this way as long as I can remember, it just doesn't seem right though.
The electric fans won't ever run unless the AC is on, it will heat up to 223 without the fans ever coming on but as soon as I turn the AC on it will cool back off to <190.
Is the sensor broke possibly? Are they all like this? If so that's a shitty ******* design.
Its not a shitty design...The car is designed and made to run that way. If it did that and it wasnt designed to run that way then yes i would have to agree with you. But the ecotec motor likes to be hot!
But heat soak sucks, you sit there for like 3 minutes or drive in traffic for a very short time and suddenly your coolant is 210+ with IAT2 of 150+
how do you get your temps up that high i can sit at the bank for 15 minutes in drive and my temp won't go past 196 driving it stays at 190 so im not sure never had the fan kick on without the ac on i know sunday im changing my t-stat cuse the seal around it it deteriating so it flatlines the dic coolant temp
Thats the best idea, just dont let the temps get over 250. I think these fans have two different relays for speed 1 and speed 2 (or the difference is in the fan, cant remember for sure). Your fan one might be dead.
