Cooling,meth?
Old May 29, 2008 | 11:02 AM
redcobaltss's Avatar
Originally Posted by LamboW9
wateva plugs you have/need depends on your stage kit ...the meth doesnt affect that...it jus helps cool the engine via a better latent vaporization of the water an the methanol boosts the ocatane therefore eliminating knock and stabilizing detonation
well i have been told to run my stock ones. i have a devils own kit and when it kicks in my boost does go up but the car hesitates. i know its cooling but doesnt respond all that well. i have the 3gr nnozzle on it and its a stage 2 with a 2.8 cai and borla muffler
Old May 29, 2008 | 11:13 AM
LamboW9's Avatar
try activating it at a higher rpm or a higher boost....they recommend you start spraying at about 70-75% of wat your total boost is...this could be your problem...when are you spraying?..stageI or Stage II meth kit?
Old May 29, 2008 | 11:48 AM
Cyclone's Avatar
Any one got the mod's i do and spraying water/meth?? I wan to do this but am hearing it is ok and is not ok because of my gm stage 2 tune??
Old May 29, 2008 | 11:54 AM
invisible's Avatar
I kinda do
With my Devils Own meth injection, The tuner pulled about 20 more whp!
Old May 29, 2008 | 11:55 AM
LamboW9's Avatar
its actually better that your staged because your heat soaking more an this will help you cool your engine down...its perfectly safe an its good for your car...it actually makes your engine last longer because it stabilizes detonation...if you have any detailed questions AIS the guy that posted a few above you just pm him an he'll give you a great detailed response or feel free to pm me
Old May 31, 2008 | 11:43 AM
Cyclone's Avatar
Bump (still dont know if this is safe for gm stage 2 tune)
Old May 31, 2008 | 01:18 PM
SSSCEnthusiast's Avatar
It won't hurt your tune, sir. It'll just be a cooling mod instead of a power mod, until you're tuned for it.
I ran on my Intense Stage 3 w/ the intense tune and methanol for 2 months, and everything was fine, so I'd say you're safe.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
