cooling mods question
Old Sep 4, 2007 | 12:12 AM
rickay726's Avatar
what does everyone suggest, who uses what and about how much does it cost and with waht mods would i need to be concerned about this?
Old Sep 4, 2007 | 08:42 AM
ifknrock09's Avatar
are you looking for to run cooler temps? or just mods in general? if you are looking for a way to cool down and a good mod is methanol injection. its a quick 20 to 30 hp. and you will run at cooler temps. check out snowperformance
Old Sep 4, 2007 | 08:58 AM
ralliartist's Avatar
ok, well first off get a cobra heat exchanger. with it mounted up front and all the extra coolant you'll have, plus you can trow in a whole bottle of water wetter, you should see about a 15-20degree drop in iat-2's. 3rd gear will feel much stronger. then get a wather/meth kit. I went with a cheaper kit, but it works just fine. it's called cooling mist. I got it off of ebay for 175 bucks. it lowers temps like 50-70degrees. the advantage to it also is that you can tune more aggressively, which results in even more power. The cooling mist kit comes with a boost activation switch. I got mine set for 7-8 psi. if you have anymore questions, just pm me.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
