copper gaskets
Old Sep 19, 2010 | 01:29 PM
blacksss's Avatar
copper gaskets
i bought a used exhaust system from some guy in illinois(mistake). Put it all on and it leaked like a bitch finally realizing the welds on the header tubes were all cracked. Took it all off and got the header sandblasted and re welded. Its a little bit better now but it is still leaking due to the header being warped about a 1/16 inch on each end. Were can i get some good THICK copper exhaust manifold, collector and exhaust gaskets from hoping it will seal the deal.
Some input would be much apprietiated
Old Sep 19, 2010 | 01:30 PM
xmusic_addictx's Avatar
I got my copper exhaust manifold gasket from OTTP.
Old Sep 19, 2010 | 01:34 PM
blacksss's Avatar
is it thick enough to seal the little warp i have?
Old Sep 19, 2010 | 01:43 PM
selfinfliction's Avatar
forget the gasket, take it off, and have a machine shop plane it out.
idk if zzp fixed their stuff by now, but i bought a brand new midlength header combo last nov-dec, and all 3 flanges were fubar. the primary's flange was so bad the copper gasket from ottp wouldn't even seal it.
but anyways, i had to get my machinist to run it across the planer to get it fixed properly... just spend the few extra $ and get it done properly, if it;s warped you will spend more time fooling with it than it's worth if you don't get it machined.
Old Oct 21, 2010 | 12:28 PM
blacksss's Avatar
Should I put the stock gasket back in afterwards then?
Old Oct 22, 2010 | 09:36 AM
mrbelvedere's Avatar
no..............
Old Oct 22, 2010 | 04:23 PM
Black SS 07's Avatar
buy a sheet of copper. its cheap cut it to your liking and make sure you dont over torque the bolts or make it uneven
Old Oct 23, 2010 | 01:36 PM
blacksss's Avatar
can i get it at the hardware store? all in all that seems pretty difficult
Turbo Johnny
Feb 21, 2019 09:41 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Macgyver2484
Sep 2, 2015 05:44 PM
