corrent psi?
Old May 6, 2007 | 11:59 AM
braddddddd991's Avatar
current psi?
im am only hitting AROUND 10 psi and its like 90 degrees out? is that about right
Old May 6, 2007 | 12:03 PM
SS33's Avatar
I assume you are stock, so you should ussualy be around 10 psi, climbing up to 12ish in the higher RPMs in 2nd and higher
NOw if you are only seeing like 8 or less in most conditions, and peaking at 10 psi than that seems low
Old May 6, 2007 | 04:20 PM
Red07SS's Avatar
seems a little low. I have a CAI and AEM filter and always see above 10psi at WOT unless im bogging the motor down or something below 3k rpm. Even above 90.
Old May 6, 2007 | 04:58 PM
Hurt-ya's Avatar
stage 1 cobalt is 10psi (12 on a cold night)
ne thing way below 10... u have a boost leak or ur vacuum isnt working right
but usually u run below 10 psi if its a humid day... all cars run shitty on a humid day
Old May 6, 2007 | 05:38 PM
chevysalesman614's Avatar
WRONG!
A stock cobalt should be peaking @ 12psi.. if you're lucky, under perfect conditions you might see 13psi
@ WOT in 2nd gear, if you don't hit 12psi then your car is messed up, or there is something wrong with the boost gauge
Old May 6, 2007 | 07:11 PM
SS33's Avatar
Stage 1 is the same pulley, therefore the same psi, as stock. The only diff. is the injectors and tune.
As we have said, 12 psi should be seen at higher RPMs (under WOT) in 2nd gear and up.
Depending on your driving style, you might not hit 12 often in daily driving. Find a nice stretch of road that you can pull all the way through 2nd, and a good ways into 3rd.
If you are not getting beyond 10 psi at all than something is up
Old May 6, 2007 | 07:26 PM
what psi should i be hitting wot in 1st gear?
Old May 6, 2007 | 07:29 PM
Red2.4SS/SC's Avatar
just though i should let you know corrent is spelled current
Old May 6, 2007 | 07:32 PM
oh i dident even recognize it
Old May 6, 2007 | 07:33 PM
yeah and its the title so it stands out pretty good , just letting you know
Old May 6, 2007 | 07:34 PM
Toronto SS's Avatar
If you can go WOT in 1st something is wrong...
Old May 6, 2007 | 07:36 PM
starting from a roll
Old May 6, 2007 | 07:37 PM
even from a 20 i get wheel hop
when im in first
Last edited by Red2.4SS/SC; May 6, 2007 at 07:37 PM. Reason: Automerged Doublepost
Mattman6's Avatar
Go WOT in 2nd and 3rd and see where you are at. You are worrying about pety things
Old May 6, 2007 | 07:38 PM
k something is up
i guess im heading to gm tomorrow
R&C_rallySS's Avatar
I'm hearing alot of strange things about stock psi. Depending on where you are will effect it slightly. However you should see 12psi peak. It also should be peaking quickly. When my car was stock I could easy hit 12 psi in first gear.
Old May 6, 2007 | 08:09 PM
SS33's Avatar
Or something is very right. I have finally killed every last bit of wheel hop and can finally go WOT in first after I get hooked up (above 3k ussually). It's a great feeling.
Check the vid in my sig if you wanna see
Old May 6, 2007 | 08:24 PM
RedEcotecSS's Avatar
i can go wot in first. usually just spin tho
Old May 6, 2007 | 09:05 PM
SSdan's Avatar
Me too until i moderate it and floor it
Old May 7, 2007 | 12:52 AM
Hurt-ya's Avatar
Originally Posted by chevysalesman614
WRONG!
read my post once more before u add ur smart ass comments
I said on a cold night u will hit 12 PSI.. on a humid day ur going hit 8-9 psi
and no u will not hit over 12 unless u have add ons
and it depends where u live at 2.... in texas its humid... so i hardly see my 15 psi on a stage 2 in lower WOT's i usually wont see my max PSI untill 6500-6800
So stfu
Old May 7, 2007 | 12:59 AM
Try2k's Avatar
^^^^^^^I live near Austin and my balt is bone stock and I hit 12.5 in second on most days....Definitely not cold outside when I do it by any means lol
Old May 9, 2007 | 04:02 AM
Hurt-ya's Avatar
yeah.. San antonio been getting Krummy weather ... :-/... oh speaking of which... the car club im apart of might be going to that austin show, we are going enter our laser... if ur going we could meet up.. i buy u a beer if ur old enough ^.^
Old May 9, 2007 | 04:39 AM
Toronto SS's Avatar
That is a sweet run
Old May 9, 2007 | 09:12 AM
Z Speed's Avatar
I live in milwaukee wisconsin and when it was cold all i could see was 10.88 psi via hptuners data logging
Old May 10, 2007 | 12:54 AM
mIkeyG312's Avatar
mines stock and i hit 12.5 .. but correct me if im wrong unless u do the boost bypass mod boost is limited in first and 2nd gear to around 10psi.. ive noticed that and thats wut ppl have told me also
