corsa leak....
Old Oct 18, 2006 | 07:46 PM
Coblt ss super's Avatar
corsa leak....
I have been hearing this leak in my corsa sport cat back and well, i finally decided to see where it was and try to fix it. Well it turns out the resonator at the end towards the rear of the car is leaking and if I can get pics i can show you exactly where. But what should i do to fix this weld it or tell corsa?
Old Oct 18, 2006 | 07:50 PM
Bad06SS's Avatar
There's a hole there for water to leak out, it's completely normal.
Old Oct 18, 2006 | 07:54 PM
oo but it sounds like **** and i think the clamp right behind it leaks too and idk how to fix that one either
Old Oct 18, 2006 | 08:06 PM
Blk06CobaltSS's Avatar
I had the same prob with the touring, i dont have anywhere to fix it or the tools so i braught it back to GM and they tightened it up but it did it again, it might be the weather change down here but i still want it fixed to be on the safe side.
Old Oct 18, 2006 | 08:09 PM
yeah same here and does yours like get louder as you turn off the car like when you turn it off sounds like you let the air out of like a balloon because mine sounds like that and then stops after like 2 seconds
Old Oct 18, 2006 | 08:17 PM
ReMz's Avatar
i have a leak too in the same spot with my Corsa Sport......
.... was concerned at first but it's a minor leak. i dont have that noise tho ^^
Maverick
Nov 18, 2013 09:27 PM
Dezod
Dezod Motorsports
31
Jul 7, 2006 10:16 AM
Skottish
Mar 22, 2006 08:50 PM
CobaltCoupeCrazy
Feb 15, 2006 12:41 AM
Yaldain
Dec 31, 2005 05:24 PM
