Could use a little help
Sooo I have had this issue awhile and being searching for a answer....so far i have gotten no where. When coming to a stop (in and out of gear) my idle bounces and some time stalls out esp. when I am in gear. It doesnt usually stall if i am out of gear. I have had a few tunes on it seeing if the issue would be resolved but it hasnt yet. So that makes me believe its something mechanical. It usually gets worse the longer i drive the car. I figure maybe i have a vaccum leak somewhere??? If anyone could help me out I would much appreciate it.
Mods Include...2.7" w/ 60lbers, header/DP/catback, intake, front mount he
mine would kinda do the same thing, and if i gave it over 50% throttle it would go into limp mode. turned out that the throttle body was bad and would lock up anything over 50% throttle. replaced the TB and all probs went away.
yah mine does the same thing..went to park the other day and idle drops below one bouncing around same thing happens when i start the car sometimes.... Not sure what it is but i just wait till it cuts off by itself which it doesnt do
sweet, i sent you a pm
changed the maps....it is a little better but still is bouncy
Last edited by PlaysWitCars; Nov 14, 2007 at 08:16 PM. Reason: Automerged Doublepost
