Cryo chillen a h/e?
Cryo chillen a h/e?
I recently acquired a cryo system (c02), I looked and found nothing. I know on intercoolers it is effective, I was going to use a spray bar to spray my zzp h/e. I was wondering pros and cons, and if anyone has did this. Thanks, Mike
You may see a very small decrease is temps. As was stated, water is harder to cool than air. If you sprayed it heavily to frost the HE before a run it may help a little, but from discussions I've seen it doesnt seem to do much on our cars
I would love to get a couple of the 3/4" fuel bars and chill the coolant directly. I'm not sure if you'd have freezing problems, though.
Don't worry about all that just spray the supercharger that is the heat source!!!!!!! You will see the most gains that way even better would be to actually design a SC spacer plate that has bulbs in it so the supercharger outlet is supercooled as well as there will be absolutly no heat transfer!
