cx racing heat exchanger
Old Oct 23, 2011 | 05:43 PM
BankerBalt's Avatar
so i'm doing a build on my 2.2 and have a small problem... i don't want to use the original plastic drain plug for my cx racing heat exchanger, i want a metal one... that being said, does ANYONE know what size bolt it is to put into the bottom drain plug for it?
Old Oct 23, 2011 | 08:48 PM
Leafydialupking's Avatar
No idea. Mine is all busted up already from bottoming it out. It wont get any worse though since I now have some protection on it. If I do somehow kill it, I'll end up throwing a thread gauge on it and making my own plug.
Old Oct 23, 2011 | 08:53 PM
advise's Avatar
mies 1/4 npt
Old Oct 23, 2011 | 09:10 PM
BankerBalt's Avatar
bottom plug, the bigger one. that's what size i need to figure out :/
Old Oct 23, 2011 | 09:12 PM
1/4npt looks about right.
Old Oct 23, 2011 | 09:50 PM
BankerBalt's Avatar
how is it 1/4 inch? half inch doesn't even fit it...
Old Oct 23, 2011 | 09:51 PM
1/4npt is quite large. 1/8npt is about 1/2inch.
Old Oct 23, 2011 | 10:08 PM
BankerBalt's Avatar
wait wtf is 1/4"npt in that case? where can i find it?
Old Oct 23, 2011 | 10:09 PM
hardware store, in plumbing.
Old Oct 23, 2011 | 11:28 PM
AjSS's Avatar
They are cheap.
1/4 in. NPT - Plug and Cap Fittings - Fittings & Plugs - Fittings & Hoses - SummitRacing.com
Old Oct 24, 2011 | 01:12 AM
insylem's Avatar
NPT = National Pipe Taper/Thread
I noticed that the "size" isnt really correct. Havn't figured out their sizeing system. IE: 1/4" isn't 1/4" if you measure it with a ruler.
Anyways NPT has a taper to it, the diamater gets wider the farther in you go. This means itll go in a couple threads and then get tighter and tighter the more you turn it. Use some thread sealant or teflon tape to sea it, as NPT does not create a seal.
Also MIP or FIP seems to work. I have the OTTP HE and it's plug 1/4" NPT.
I got mine at Home Depot or Lowes, I think it was Home Depot
Old Oct 24, 2011 | 08:32 AM
BankerBalt's Avatar
Awesome thanks guys
DarrenGC
Dec 24, 2021 01:55 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
