devils own meth kit?
Old May 25, 2007 | 12:38 AM
peck05's Avatar
for anyone running with this, need some opinions on how you like it? and how well is it working? it would be a great help, thanks
Old May 25, 2007 | 10:10 AM
BlackSS/SC's Avatar
I've got it, the progressive kit and it works great. I'm able to run 23 degrees of timing no problem at all and before I could only run 14-15 degrees of timing.
Old May 25, 2007 | 10:12 AM
Gixxerboy02's Avatar
I to have the progressive kit. I m running 24 degrees of timing with no problems.Easy to install.I love mine.
Old May 25, 2007 | 10:50 AM
eastcoastz's Avatar
You guys ave it trunk mounted? Also did you use a throttle body spacer?
Old May 25, 2007 | 10:54 AM
BlackSS/SC's Avatar
Mine is trunk mounted and I'm using the M5 nozzle in my CAI.
Old May 25, 2007 | 11:03 AM
607Motorsports's Avatar
I also have the progressive devilsown kit and love it, 22 degrees here on a meth mix and 25 on full 100% meth.
Sorry to get off topic but what are you guys seeing for IAT2 temps while cruising and under a 3rd gear pull guys? I think i'm having either an air lock or my IC pump isnt working right now
Old May 25, 2007 | 11:08 AM
BlackSS/SC's Avatar
My IAT2 temps were crazy yesterday for some reason. Cruising they wouldn't go down below 108*F and were up to 120*F when sitting at a stop light. WOT pull I get up to 150*F. This is all on a 19*C day.
Old May 25, 2007 | 11:20 AM
yeah man my IAT2 temps were crazy yesterday as well. I think I might still have a bit of air in my h/e but i was at about 110-115 cruising and then at about 175 or so on a 3rd gear pull. It was 85*F here when I did pulls though...
Old May 25, 2007 | 11:27 AM
2K5SS/SC?'s Avatar
I have the Devil's Own kit with the boost sensor, not the progressive kit. It works awesome. I'd give more details, but I never got around to bumping up the timing since my 3rd gear broke. I absolutely love the kit though because it prevents the blower from heat soaking, and the grape additive in my methanol smells awesome!
Old May 25, 2007 | 11:29 AM
BlackSS/SC's Avatar
Ouch, I'm wondering if the pump can get weak and not pump like it should or if it just dies when it goes bad. I have the extra resivoir and the cooland in it was luke warm and the hoses were barly warm to touch when my temps were that high.
Old May 25, 2007 | 12:15 PM
eastcoastz's Avatar
Which progressive controller you guys have? 2 or 3 bar?
Old May 25, 2007 | 12:27 PM
2 bar
Old May 25, 2007 | 12:42 PM
BlackSS/SC's Avatar
2 BAR, but our car's have a 2.5 bar MAP sensor so that means what the controller says for turn on point and full boost settings are not the same as they say.
Old May 25, 2007 | 01:54 PM
very good point blackss/sc. I'm actually running a 3 bar controller on my car. It's simple enough to dial in where you want the starting and full spray points. What are you guys doing for those? I'm at about 6-7psi start and 13-14psi full spray with a peak of about 21psi. I don't seem to get any bogging and the charger is ice cold after a pull
Old May 28, 2007 | 12:35 PM
shaunmcdee's Avatar
i thought u guy had to install the meth injection kits after the blower, due to the rotors on the blower having a teflon coating, and will eventuallyfail?
Old May 28, 2007 | 01:10 PM
eastcoastz's Avatar
No teflon on our Gen 5 M62 superchargers.
So you guys with the kits which should I order a progressive kit with a 2 bar or 3 bar controller. I was thinking 3 bar, but Im not sure.
Last edited by eastcoastz; May 28, 2007 at 01:10 PM. Reason: Automerged Doublepost
Old May 28, 2007 | 03:19 PM
shaunmcdee's Avatar
so its safe to run meth injection before the blower without worrying about killing our blowers?
Old Jun 10, 2011 | 10:10 PM
gbkglenn's Avatar
where do you install the injecter ?
Old Jun 11, 2011 | 05:13 AM
SatanzSS/SC's Avatar
x2. also want to know this.
Old Jun 11, 2011 | 06:23 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
I have the stg1 kit, love it. Mounted in the trunk, spraying into my cai pre-blower :P
Old Jun 11, 2011 | 06:48 AM
gbkglenn's Avatar
could post a pic so i can see? and is the stage 1 kit the same as the DVC - 30 KIT ?
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
