diamond racing pistons
Old Dec 11, 2006 | 05:34 PM
CbYellowSS's Avatar
where is the cheapest place to get diamond racing pistons????
i heard getting them directly from diamond is best but what is there website???
Old Dec 11, 2006 | 06:07 PM
Goin2Fast06's Avatar
try going to diamondracing.net I havnt look at it yet but its worth a shot.
Old Dec 11, 2006 | 11:50 PM
06noscobaltss's Avatar
go to their website and call to place the order! I saved over 200 by going direct! WOOT!
Old Dec 11, 2006 | 11:58 PM
2K5SS/SC?'s Avatar
If you go direct and save $200 they won't come with the special coating Intense has put on them. That coating is worth the extra money because it'll help prevent detonation, and keep the pistons cooler. JE and other top brands are going to this as well. Just figured I'd give you a heads up.
Old Dec 12, 2006 | 12:01 AM
campo165's Avatar
is the pistons the single only weak point on our engine? i mean so far at least...
Old Dec 12, 2006 | 01:06 AM
2K5SS/SC?'s Avatar
The pistons and headgasket are the weak points of the engine. After that, the vavletrain and balance shafts should be replaced to raise the revs above 7000-7200 rpms.
Old Dec 12, 2006 | 08:55 AM
crossed over's Avatar
is raising the rev limiter that beneficial? i figured it would cause more problems in the end, especially with heat?
Old Dec 12, 2006 | 10:14 AM
2K5SS/SC?'s Avatar
crossed over, PM me if you want to chat on the valvetrain and rpm raising. I don't want to invade a piston thread with valvetrain stuff.
Old Dec 12, 2006 | 10:28 AM
cawpin's Avatar
Personally, I wouldn't want anyone other than the manufacturer doing ANYTHING to my pistons. They designed them, they tested them.
Old Dec 12, 2006 | 10:38 AM
hatrickstu's Avatar
^^^ its intense man they know enough to be trusted with putting a coating on a piston
Old Dec 12, 2006 | 11:33 AM
2K5SS/SC?'s Avatar
These coating are to increase power and reliablility. When you start making big power and heat, just the run on the mill stuff doesn't always work. If you want the best you will pay for it. Will it work without the coating, absolutely. Would it be even better if the part stayed cooler, prevented detonation cause it stays cooler, and holds up to extreme conditions, it certainly would.
Old Dec 12, 2006 | 11:45 AM
Doc's Avatar
Doc
If the coating is that much better, why didn't the manufacturer apply it?
What are the quality controls for applying the coating?
Who monitors the thickness of the product being applied?
Then again, this is about where to find the cheapest set of diamond racing pistons, not debating the worth of applying a coating to the piston.
I believe the question has been answered and the reason its sold cheaper at the manufacturer's site vs. an aftermarket supplier.
Old Dec 12, 2006 | 11:50 AM
Marchi1's Avatar
What si the coatng that they place on them? some sort of teflon derivative or what?
Old Dec 12, 2006 | 01:09 PM
2K5SS/SC?'s Avatar
Intense would have to chime in on this one. There are many coatings and procedure available. I'm not exactly sure which one they use.
Old Dec 12, 2006 | 06:06 PM
Marchi1's Avatar
Went and asnwered my own question with a moly coating on the sides, and a ceramic coating on the tops.
Old Dec 13, 2006 | 10:28 AM
CbYellowSS's Avatar
go ahead its no big deal to me...
i want to see intense in here to explain some stuff... that would help alot
Old Dec 13, 2006 | 10:44 AM
Evilfrog's Avatar
Send them an email. They dont check this board everyday.
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
