Different stock HPs ?? Im confused
Ok the manual i believe says the were rated at 205 hp at the wheels. But as i been doing some research ive been seeing that this may vary. ive seen people on this sight talk about having up to or around 205 to 220 Hp or somewhere in between, after being dynoed at stock. This was interesting to me. I guess cause no car is the same, or it depends on the supercharger. I dont know i just thought it was cool to know that you might have more than you thought you did. Kinda like a grab bag.
It has been very interesting to see everyone with diff #'s usually a car dynos in a narrow range but our cars are unique like that. Our range is like 197 - 236 hp. Large range but u have to take into account what gear and what kinda of dyno, condition, setup. But it is coo that on average our cars have more than 205 hp.
under the same conditions, every cobalt ss s/c has as much HP as the next one. people have been sayin 06's are a little faster then 05's but not by much. but the difference in dyno #'s is because of numerous factors, not because of some SS s/c's are faster then other SS s/c's
This is actually common on all vehicles...just an error percentage. It is very dificult to produce an engine that creates the same numbers time and time again, that's all. And to be safe GM underrated the motors so you get an actual 'real world' number.
It is true that the dynos diffs do account for some variability too though.
Originally Posted by Pully Police
The 205 hp rating is at 5600 RPM. Our cars build power to redline -> so about 220ish at 6500 RPM.
-P
-P
Moderator Alumni
Originally Posted by retrop
Not true at all....every engine is different so there can be varying power outputs within the same exact model cars. The 205 is an average rating.
EXACTLY!!
EXACTLY!!
1 Post
Originally Posted by zinner
All the engines are very very close to the same. Mass production makes sure of that. There is no way one engine is going to make 205 HP and another is going to make 230 HP, it's that dyno's aren't are calibrated the same.
you have to consider conditions when dynoing as many have said. more specifically what gas are you running. is it good from the station you bought it from. what kind of dyno, is the dyno rolling resistance the same as the next? should be but is it? what is your altitude. what is the temperature, and humidity.
When it comes to engines the major reason why there is performance variances is due to cam timing. that is why you can buy adjustable cam timing sprockets. not only can you tune with the timing of your valves you compensate for the few degrees that the factory cam is off from factory. With road race bikes we have found large performance gains in some and in recent years we have gained the experience to check the timing before ordering the cam sprockets. we just wanted to ensure we needed them before buying them. We had seen a large increase in accuracy of getting cam timing correct right from the factory.
I am a Machinist/Tool Maker and run a CNC machine and i can say that Mass Production does NOT mean identical parts .... one part will be off from the next even in the best machine .. it could be a few .0001 or even +/- .0015 depending on wht they call out for on the prints. so yes even a thousandth here or there could make up a 10% or more diffrence.
GM rates all hp at the flywheel (AKA crank) they are under rating the 2.0 S/C.
Agreed
Cooler air, maybe around 65F, is good and is why many performance cars try to gather air from outside the engine compartment. On days when the temperature is oh... 95F... gathering 65F air is not possible without an air cooler.
Physics...
A dyno is a tuning tool. They can be quite effective provided you use the same dyno before and after a mod and try to re-create the variables as much as possible. The variable of correction factor,weather conditions and dyno calibration are more likely to affect such a large swing in numbers. A wheel dyno is to a car what a bathroom scale is to a women. We all know a women that will only weigh herself on certain scales because she likes the number she sees when she looks down. This is usually the same women that will not wear a bikini at the beach
Peace
Steve.
haha i used 2 use cnc machines in my major in High school. i never said anything about 06's being faster then 05's i just stated htat some people think that is true. me personally i think they are the same (cough* 2006s are better *cough)
true there are always slight differences in mass production but 99% of the cars produced will be the same as the next one IN THE SAME CONDITIONS!!!!!!! the same car with the same motor with teh same supercharger boost with teh same engine calibration doesnt make for differences of 20HP.. 1-2HP yes, but what some people are suggesting is crazy
Originally Posted by tio
Understand what you are saying. My father in-law is a millwright,my brother in-law is a machinist, and my other brother in-law is a tool & die maker. (Dinner conversation is F**king brutal with these guys ) but 10 % variable in horsepower is huge. It has been many years but one of my first jobs was rebuilding small block V-8s in a performance shop. This was way before the CNC became maintstream. Although engines have changed a great deal since then, a gas engine is still fuel,compression and ignition. At least one of these has to be changed to increase horsepower. I realize that the parts used are not identical,but, they are really close (within a few thou). If the variable of tolerance was an issue here, why are there not some SS/SC guys claiming some low dyno numbers ? If numbers as high as 236 whp are being claimed should there not also be some guys complaining about 174 whp ???
Peace
Steve.
Peace
Steve.
I agree. I seen on here people get anywhere from 200-230 whp on the dyno. it's because of the dyno, I don't believe there can be a 30 WHP difference between 2 stock cobalts.
look at the track times people post, most(not all) run around the same mph.
same day,same dyno, the cars are going to dyno almost the same in most cases.
Peace
Steve.
Peace
Steve.
Originally Posted by avro206
Is it just me--or did know one set this man straight?
