dipstick keeps popping out.
title says it. i guess i have too much pressure building and its popping my dipstick out (yes, thats what she said
) and im losing oil all over my engine bay.
any ideas?
Thanks in advance.
) and im losing oil all over my engine bay. Thanks in advance.
i remember something about a bad intake manifold gasket causing the crankcase to pressurize. cant remember if there is a bulletin on it or not. however before doing anything there id do a compression test, or better yet, a leak down test. make sure its not something more serious.
THINK WITH YOUR DIPSTICK JIMMY!!!!!
sorry someone had to say it
so, my .02 wasnt too helpful, hope you got a good laugh and arent stressin out as much about it.
my advice, look at the thread posted above
usually means your rings are going.. same thing happened to me 2 weeks ago.. do a compression check and a cylinder leak down test you can buy the whole kit at harbor freight. I just pulled my engine apart last night and found out that I broke the ring land on piston 4 and 1. What are your mods.
If your running high boost it happens if you dont have a proper working pressure control system. I doubt it's your rings. Your dipstick tube o ring could be bad. Like said your intake manifold gasket. I used a clamp and a spring to hold mine down on the Dsm. when you run a lot of boost though you usually need to use a spring to hold it down.
im running 20+ and its something that just doesent happen on these engines unless its a major mechanical problem cracked rings or broken piston and on a super rare occasion a bad check valve in the intake manifold not being a dick but you need to read and learn more about the ecotecs they arent a dsm
How much air flow are you seeing. 20+ psi on a tiny blower is different than a big turbo or something that actually flows a lot of air.
I was seeing over 50 lbs/min. The car I have now did it until I switched intake manifolds and put a new gasket in there. If he has a broken piston or cracked ring the loss in compression would be apparent. That's not going to go unnoticed. He didn't say his car runs like ****. He said his dip stick is popping out..... Also he didn't say it was smoking.
Well good to know. Good thing I put diamond pistons in. Even if it needs new pistons or rings pull the head and drop the oil pan. All you'll need Is a head gasket rod bearings and rod bolts. Not a hard job to do. If there isn't damage to the sleeves it will be good to go. That's crazy you couldn't find anything with a compression test and leak down test. I didn't know that could happen. I was just giving other suggestions that I have seen cause this issue. My bad.
You guys are going to have to stop being doom and gloom on these things now that the cars are getting older clogged "lifetime" pcv valves and bad intake manifolds are going to start being the main cause of these things rather than just people sucking at tuning.
