do we have a front diff?
Old May 14, 2008 | 05:40 PM
InovatedSS's Avatar
do both wheels spin or just 1 on our balts?
I have no idea. lol
D4u2s0t's Avatar
depends if you have a lsd or not
Old May 14, 2008 | 05:41 PM
InovatedSS's Avatar
how would i know if its limited slip? i bought the car but i never asked if it had that.
Old May 14, 2008 | 05:43 PM
HickOverLOrd's Avatar
Does it say G85 on the sticker anywhere? What year? If its a 05 or 06 and you have recaro seats then you have a limited slip.
D4u2s0t's Avatar
if you purchased the g85 package you have a lsd.
originaladrian's Avatar
check ur vin to see if u have the g85 pckg
SSRedSC's Avatar
Does it have recaro seats? Limited slip came with the g85 package in 05 06 which included recaro seats. In which case, your seats would say recaro on them.
Old May 14, 2008 | 05:46 PM
InovatedSS's Avatar
its an 07
Old May 14, 2008 | 05:48 PM
only way to tell then is if you can see g85 on your sticker anywhere or look up your vin.
Old May 14, 2008 | 05:56 PM
InovatedSS's Avatar
do we have an open diff, and would it be a bad idea to go turbo if i dont have the lsd??
im planning on buying the hahn turbo by the end of the summer i know ill spin a **** load more with no lsd but would it still be ok to turbo?
Old May 14, 2008 | 08:10 PM
rukkee's Avatar
Give me a shout with your vin and i can tell you one way or the other .
Old May 15, 2008 | 11:06 AM
Jkunzy1690's Avatar
LSD brother, wish i had it, if you do im jealous!
Old May 15, 2008 | 11:54 AM
Mss26's Avatar
ALL cars have differentials... a LSD is a different type. yes let the arguments being.
oh nvm i see someone already said that..
Old May 15, 2008 | 12:02 PM
schamsy's Avatar
Having or not having an LSD should not stop you from going turbo...
Old May 15, 2008 | 02:18 PM
InovatedSS's Avatar
i just wanted to see how much more slipping i would get from the turbo if i dont have a lsd.
i got a TD wont help much but stops from wheel hop, i just still wonder if ill be ok with not having a lsd and going turbo
Old May 15, 2008 | 04:06 PM
RedEcotecSS's Avatar
how do you 'check' a vin?
Old May 15, 2008 | 04:20 PM
silverfae7's Avatar
I you pick up your trunk floor to access the spare, look on the left corner and there will be a sticker with a bunch of numbers in alpah and nuerical order. These are your regular production options (RPO)codes. If you see G85 listed, you have a limited slip diff.
Old May 15, 2008 | 04:23 PM
Area47's Avatar
Rent me! per hour
the overlooked quick answer question. do you have heated seats.
Old May 15, 2008 | 04:24 PM
campo165's Avatar
to answer your first question...both tires spin, regardless of whether you have a limited slip.
Old May 15, 2008 | 04:25 PM
PinaSS's Avatar
dont worry if u dont have lsd both of ur front tires still spin there is a thread about this already. Gives a clear detail what lsd is.
Old May 15, 2008 | 04:27 PM
Area47's Avatar
Rent me! per hour
you can spin both tires with an open diff.
Old May 15, 2008 | 04:42 PM
Saltbager's Avatar
Just post up your VIN and I will check it through GM to tell you if you have one or not. Some other people on here might be able to do it also. Us GM techs have access to that information, we are able to look up the build of the vehicle with the VIN number
Old May 15, 2008 | 04:47 PM
SJSchafer's Avatar
lol. look at the tranny. Either it says LSD or does not.
Old May 15, 2008 | 05:49 PM
heated seats = no lsd?
Old May 15, 2008 | 05:51 PM
M-Dub's Avatar
heated seats = LSD
