Does anything go way?
Old Apr 4, 2011 | 08:32 AM
crazywhiteboy89's Avatar
Today I was driven my car and all of a sudden I stop did so crazy idea surge **** and stalled than got a code po103 what can I do to fix it?? O I just clean the throttle body last tuesday change plugs and clean the maf sensor, it drove fine till this morring please help
Old Apr 4, 2011 | 08:59 AM
Old Apr 4, 2011 | 02:09 PM
Old Apr 5, 2011 | 08:03 AM
Xephirothx's Avatar
when you cleaned the throttle body did you put too much pressure on the butterfly valve? i've heard they can break somewhat easy if ur too rough with em... p0103 is a maf code can mean several things..check for leaks, make sure the maf is bolted down tight enough, and make sure ur air filter is on and you have no leaks around the intake for that matter. hope it helps
