Does this supercharger look okay to you?
The lack of teflon coating or what ever people are referring to it as, seems to be debatable when referring to performance.
Some people have the problem, and many others do not, however is there any evidence such as loss of boost or high Ia2's which suggests that this lack of rotor coating robs performance or longevity of the supercharger?
Yes and yes. The abradable coating helps keep temps down as well and protecting the rotors from causing damage when they rub. If the coating is gone the SC will generate extra heat as well as cause scarring on the rotors which effects performance as well. Eventually the rotors will be damaged to the point where they cannot efficiently compress air at all.
z28addiction
Sep 28, 2015 12:03 AM
