Does this timing chain look like its ok?
Old Nov 15, 2008 | 02:32 PM
mrphoto103's Avatar
From: Voted by the people, most likely to get pulled over by a cop
Here is where I'm at with Dylan's car. I want to make sure that the timing chain is set correctly before I button everything up. There is the small hiccup (click click) that Im concerned with. The teeth do not jump, the tensioner is in correctly, and the guides are all torq'd down to spec.
Please give me your thoughts, thanks
http://www.youtube.com/watch?v=35OeyQzl89w
Old Nov 15, 2008 | 02:58 PM
ralliartist's Avatar
hell no that's not ok. Jesus, just be glad you haven't actually started it yet.
Old Nov 15, 2008 | 03:32 PM
mrphoto103's Avatar
well, thats why i havent =)
I'm looking for input as to what direction to go in. I keep leaning towards a tensioner issue. The tensioner is out all the way. I've taken it out like 8 times to make sure. It doesnt come out any more? If I take it a notch down it comes apart
Alpha may have figured out what is wrong...
Seems that I may be missing a hydraulic piece.
Last edited by mrphoto103; Nov 15, 2008 at 03:32 PM. Reason: Automerged Doublepost
Old Nov 15, 2008 | 03:37 PM
Area47's Avatar
Rent me! per hour
it's fine. if all the links line up right and there is nothing stopping it from turning over. fire it.
Old Nov 15, 2008 | 03:46 PM
Witt's Avatar
Never want more than a few tenths of an inch of timing chain deflection between the gears.
It needs to be filled with oil before you can tell for sure. If its dry then it will collapse. I also don't see any missing pieces on that tensioner.
Old Nov 15, 2008 | 03:49 PM
ilovecars's Avatar
No!!
Old Nov 15, 2008 | 03:55 PM
Area47's Avatar
Rent me! per hour
mine did that when i had the 272 cams in the car. a slow spin will result in said deflection.
new tensioner as well
neener neener.
Old Nov 15, 2008 | 04:02 PM
Witt's Avatar
neener neener.
Yeah there will be some deflection because air is in the tensioner but I never had that much before unless it was bone dry.
Quick way to find out is just fill it up with some oil and try compressing it by hand. If you have a piece missing, you shouldnt have any more resistance than the spring.
Old Nov 15, 2008 | 04:15 PM
Area47's Avatar
Rent me! per hour
damn. you're not in a fightin mood today
Old Nov 15, 2008 | 04:18 PM
mrphoto103's Avatar
lol, glad i could try to help Area =)
the only piece i didnt photograph was the small plunger that sits in the tensioner to act as a guide for the spring
Old Nov 15, 2008 | 04:24 PM
Area47's Avatar
Rent me! per hour
thats not the gm updated tensioner is it.
Old Nov 15, 2008 | 04:30 PM
mrphoto103's Avatar
no, its an original from the 04 RL
Old Nov 15, 2008 | 04:32 PM
Area47's Avatar
Rent me! per hour
get the updated one for security measures
Old Nov 15, 2008 | 04:42 PM
mrphoto103's Avatar
thanks, didnt realize there was one. Know what they run off hand?
also, do you guys feel confident that its some kind of tension issue only (if anything) and that i can put the oil pan, front cover, etc back on the car? Or should I wait?
If it matters there are 78lb dual valve springs in there. Not sure if that is adding to how dramatic its turning over.
Old Nov 15, 2008 | 05:01 PM
Area47's Avatar
Rent me! per hour
do the colored links line up? 10 and 2 for a quick reference with number one at tdc and the crank pulley timing mark lined up on the front cover. the cam gears have marks on them that say int and exh. more or less
Old Nov 15, 2008 | 05:13 PM
AlphaJaguar5's Avatar
He has the updated one, the old one has a green gasket half way down the chamber.
This one has no gasket so therefore = the correct one.
Old Nov 15, 2008 | 05:22 PM
Area47's Avatar
Rent me! per hour
okie dokie
i didn't put it in the car. warranty work ftw!
Old Nov 15, 2008 | 06:20 PM
06blackSC's Avatar
Area beat me to it. Its just not having oil in the tensioner that is allowing the cams to 'spring' forward or back like that because of the cams interacting with the valve springs. nothing more i can say that hasn't been said already but double and tripple check your timing and you are on your way.
Old Nov 15, 2008 | 08:10 PM
mrphoto103's Avatar
yup. exhaust cam at 10 intake at 2. red red and green lined up top n bottom.
im sure everyone can understand my paranoia =)
I just dont want to button it back up to find i have to take it back apart.
Last edited by mrphoto103; Nov 15, 2008 at 08:10 PM. Reason: Automerged Doublepost
Old Nov 15, 2008 | 08:11 PM
Area47's Avatar
Rent me! per hour
i do believe im the most paranoid lsj owner on here.
Old Nov 15, 2008 | 08:42 PM
mrphoto103's Avatar
Ask around. You and I would get along famously then.
so i added some oil to the tensioner/tensioner bolt and it is a little tighter but still has a little bounce to it like in the vid.
For everyone.....If this was your car would you run with it? If not what would you do?
Old Nov 15, 2008 | 09:16 PM
y2kzman's Avatar
Mine was exactly like that when I put my engine back together. I just cranked the motor a few times with the starter with valve cover off and fuel punp relay pulled to watch the chain and after one or two revolutions oil pressure worked its way into the tensioner and the chain was super tight through a full revolution. As long as the timing marks are lined up you are fine.
Old Nov 15, 2008 | 09:52 PM
mrphoto103's Avatar
Thanks. Its good to hear from people who have gone through the same thing.
I spoke to the boss and he said (based on word from Sunburst and you guys on this thread) that we are going to roll with it.
Tomorrow goes on the front cover, oil pan, tensioner bracket and Alt, etc to do the final putting together.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
