Downpipe Gains
Downpipe Gains
What gains can be expected from a downpipe upgrade? Recommendations?
Buuuump
Buuuump
Last edited by Immortal Technique; Mar 1, 2008 at 01:20 AM. Reason: Automerged Doublepost
why not go for 3" pipping that will give you more space and get you a little bit better flow of your exhuast, giving you a better gain along with whatever else you put on it, like a DP or cat back... unless you already have 3" pipping
so all you have to do is go to your local muffler store and order 3" pipping and ask them if they can connect it to your muffler tip and to whatever your going to put on it like the DP or cat back, it shouldn't be that hard for them and it should only run you about a hundred bucks maybe
From the research I did a while back, I heard that our downpipes were not severely restrictive in comparison to other cars. And it also took like 10 posts before any numbers came up as an issue in this thread haha. Personally I wouldn't expect to see much more than 3-6whp from a dp. Not a whole lot of solid dyno numbers as most people don't go back for just a dp upgrade ya know?
Also good choice on the 2.5" exhaust. It suits us fine unless you intend on pushing more than 250-260whp
The downpipe broke or the bolts securing the downpipe broke? The shitty bolts are a common thing. Just need to upgrade to grade 8.
